Sick of it........Steering screech!
Discussion in 'The Garage' started by jakeslim, Mar 16, 2003.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Ok, money is not an issue. What do I buy to set up a premium steering setup? What pump would you buy(or have)
    ? What else? I have an old pump that leaks. I am not sure about the steering box, but I am finding from experience that if you want it fixed, buy a new one! ANY suggestions are welcome so I can get moving on this. I will be putting in a d60 and am upgrading from 35's to 38's.....MISSION: STOP SCREECHING.
  2. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    my pump screeches to when im going slow...is it becuase its leaking? i dont think mine does..
  3. Bruiser
    Bruiser 1/2 ton status
    May 21, 2000
    320
    Caldwell,Idaho
    It screeches cause the belt is slipping, I have A/C and it never screeched until I was moving to Idaho and took the A/C belt off (not charged) now with just one belt it screechs. I grandfather used to say you can rub bar soap on it and will stop the screeching but don't know about it. First you can make sure belt is as tight and is not glazed. If you look at it and it is shiny then it might be time to replace it.
  4. crwln73
    crwln73 1/2 ton status
    Sep 6, 2002
    362
    Clovis,Ca
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok thanx...would that also be why it screeeches a tiny bit when i first start it..cause i think thats from a loose belt or something..
