Side exit exhaust-Fumes in the cab? Installed 3/23 w/pics
Discussion in 'The Garage' started by KevinsK5, Mar 13, 2007.
  1. KevinsK5
    KevinsK5 1/2 ton status Premium Member
    Jan 17, 2005
    257
    13
    Golden, CO
    Anyone ever put side exit exhaust B4 the rear tires on a K5? I was going to run turndowns off the mufflers and call it good, but after driving it that way, fumes still get in with the back window down. I want to put a pickup tailgate on, and remove the doors but leave the top on. Will side exits cure the fumes problem with the top on? Thanks, Kevin
  2. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    well when i finish up my lift im rerouting the exhaust to exit before the rear tires.. ill let you know if noone else chimes in
  3. Kyle Strong
    Kyle Strong 1/2 ton status
    Sep 26, 2005
    280
    Eugene, OR
    Don't know. I seem to remember reading on here that it's not too bad, but side exits after the tires were better...but next week I'm going to run it in front of the tires like you're thinking.
  4. k5onswampers
    k5onswampers Registered Member
    Mar 9, 2005
    90
    Port Saint Lucie, Florida
    I also heard it was better behind the rear tires that is what I plan on doing and I also tried driving with my window up about 4-6" and it seemed to stop the exhaust fumes from coming in.
  5. K5Greek
    Nov 25, 2005
    2,054
    Vineland, NJ
    right now mine are behind the rear tires and no matter how i have the window if im accelerating i get tons of fumes.. so its going to be worse when i move the exhaust in front of the tire?
  6. KevinsK5
    Jan 17, 2005
    257
    13
    Golden, CO
    I've been searching and that was the general consensus. I don't really want to run tailpipes, don't want to smash them on anything. Maybe the turbulence created by the tires will throw the exhaust around a little more? Or, maybe the fumes will get caught in the low pressure area as they go rearward and go right in the back.:thinking:
  7. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    Don't know. I do know that anything's better than having no pipes out of the muffler, and having it right beneath the rear seat:doah:
  8. Elevator Man
    Elevator Man 1/2 ton status
    Dec 23, 2005
    240
    Bigelow, Arkansas
    I have mine exiting b4 the rear tires and I like it, there are litterally no fumes in the cab. The only draw back I can see is its hella loud when you have the side windows down!! hope this helps.
  9. KevinsK5
    Jan 17, 2005
    257
    13
    Golden, CO
    Sure does. Do you run around with the back window down? Any fumes then?
  10. Elevator Man
    Dec 23, 2005
    240
    Bigelow, Arkansas
    Since I've done it I hav'nt had any problems with fumes with the window down:D
  11. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I have a single 3" exhaust exiting on the driver side behind the tire and with the rear window down i get exhaust fumes in the passenger compartment. My tip is angled backwars also and it still gets in.
  12. Bow-Tie-Boy
    Bow-Tie-Boy Registered Member
    Feb 14, 2005
    71
    Ft. Hood, Texas
    I thought the fumes were a good thing? They sure do make the trips seem shorter!:D :haha:
    Headers, cherry bombs, and.......lots of fumes. I don't run a top, ever, so sometimes in the winter the warm exhaust is a welcome warmth. Maybe that's what is wrong with me.
  13. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    Man, it's trippy...:eek1: Really relaxing though...the headaches were the only drawbacks I could come up with!
    But seriously, I think behind the tires is better, but I want it in front of the tires. Looks cooler, and I don't mind a little exhaust.
  14. K5Greek
    Nov 25, 2005
    2,054
    Vineland, NJ
    cool thanks
  15. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    My buddy bought 76 K10 shortbed back in the 80's that had pipes in front of the rear tires. I didn't think much about it until we were wheeling one day and he hung one of the pipes on a log he was climbing over. The weird thing was, it hung long enough for his rear tire to actually run over the end of the tip. Just by chance I had a chain style exhaust cutter in my toolbox and we had it crushed part cut off in no time. But, I figured right then that I wouldn't ever run my exhaust that way.
    Right now mine exits in stock location behind the rear wheel. I don't get any exhaust fumes inside when I drive with the rear window open. After the lift is done, I'll be locating it up higher (as tucked up as I can anyway), in the same area.
  16. 5280k5
    5280k5 1/2 ton status
    Dec 18, 2005
    1,175
    Aurora, CO
    My blazer had glasspack side pipes when I first got it, No fumes but they may as well been rock sliders as low as they sat below the rockers. Right now I've got the mufflers with turndowns located under the back seat area, get a little bit of fumes sitting at a stoplight. Definitely don't notice it all once the top & door are off, go figure:haha: My old '77 had side exit all the way behind the rear wheels, kind of angled out and down like the 68-69 camaros and sucked crazy fumes in with the back window down.
  17. k5onswampers
    Mar 9, 2005
    90
    I also think alot has to do with how far out from under the truck the pipes are I think it will be better the farther you get the exhaust out from the side to kind of break the suction
  18. Consciouseye
    Consciouseye Registered Member
    Dec 7, 2006
    38
    Maryland
    exhaust out the back
    I am running dual exhaust out the back. 75 degrees today so I decide to put the back window down when I went out for lunch. I smelled like exhaust for the rest of the day and had a kinda neat headache. I was also looking into having the exhaust exit out of the side.
  19. HEAVY METAL
    HEAVY METAL 1/2 ton status
    Jan 10, 2005
    386
    Maple Ridge B.C. Canada
    i have duals exiting behind rear tires... you need the air form the side of the vehicle too carry the exhaust away.. NOT into ur cab... ive doen jus t bout every exhaust option on these blazers....out the back dual and single...exhaust comes in.... short dumps underneath.. exhaust comes in... side exit right before rear tie.. was the worst one i did.. too loud, and major exhaust.... specially when idling/ wheleing really slow...
  20. mrk5
    Apr 20, 2004
    12,351
    1,050
    Northern Colorado
    I've heard the little airfoil-wing-dam thing that some blazers have above the rear window helps cut the fumes from rolling in the back window.
