Side marker lights
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by SilverJim, Apr 12, 2002.
  1. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    I'm wiring my Jimmy up right now and everthing is going pretty well, but I can't remember if the side marker lights come on with the headlights. Are the side marker lights running lights too, or just turn signals? Or are they only running lights?
  2. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    Only running lights both front and back.
  3. cleszkie
    cleszkie 1/2 ton status
    Apr 23, 2001
    121
    Santa Ana, CA, USA
    My front side markers are also turn signals. The rear side markers are just markers. BTW, I have a 72 K5.
  4. 72gmc-burb
    72gmc-burb Registered Member
    Oct 22, 2001
    14
    Colorado
    Both front and rear are markers on mine.
    It always seems that the ground (thru retaining screw) often needs attention on the side marker lights. I've had to clean mine up several times over the last decade.
  5. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    My 71 Blazer's marker lights all come on when the lights come on.The two front one's blink when you use the turn signals.
  6. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    sounds like you have conflicting answers. Here's an easy solution. If your pigtail coming out of the light has 3 wires or connector pins, then you have running lights, and a blinker. If it has 2 pins, you have just running lights. One wire is the ground, one is running lights, and the third, if applicable, is your signals.
  7. SilverJim
    Sep 23, 2000
    105
    Evergreen
    The new plugs I ordered from LMC only have 2 wires coming out of them...but then a friend with a 72 pickup told me his front markers are turn signals also...I was just confused. Looks to me like I'm going to have markers.
  8. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    '71 was the first year that the front side markers blinked with the turn signals. They were still the same single filament bulb, they just go on and off with the turn signals. In other words, the lights are the same, but the wire harness is different.
