side mirror blows in at highway speeds
Discussion in 'The Garage' started by K5dreamer, Mar 3, 2007.
  1. K5dreamer
    K5dreamer 1/2 ton status
    Mar 14, 2005
    3,084
    Alexandria, Va
    anyone know how to fix this? is there a set screw? adjustment? or is this just caused by worn bushings? every time i close the door the driver side mirror flips inward almost to the door, and just driving down the road at 50mph the mirror will be blown in by the wind. its rather dangerous actually. thank god for all the big windows on this thing.
    is this an easy fix or am i going to have to replace the whole mirror assembly?
    thanks all.
  2. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
  3. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    Mine won't even move!
  4. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    i just threw a drill bit into the shaft of the mirror. then screwed it with a drywall screw. works like a charm. but ya gotta throw it real hard. lol just kidding drill a hole and then put a screw in it
  5. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,924
    336
    Fort McMurray, Alberta
    Easy fix for everyone... Take the screw at the bottom of the mirror out, and slide the plate up and out of the way. Then loosen / tighten the 10mm / 3/8" bolts as required :)
  6. dyeager535
    26,980
    Take the mirror cover off, (have fun keeping that rubber mirror cover grommet in place lol) look in there, look at how the shaft is "pinched". Cut a bicycle tube up, put the section around the mirror post where it gets pinched, and tighten it up. Not too much or the mirror will never move and rip your door up if it gets hit, but setup right it will allow it to move yet firm enough not to move when you shut your door. :)
  7. dmanblazer
    dmanblazer 1/2 ton status
    Sep 5, 2004
    165
    Wellington, Kansas
    X's 2
  8. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Saweet now I can fix my passenger side mirror!!!!
  9. willyrocket
    willyrocket Registered Member
    Mar 8, 2005
    24
    Cape Cod, MA.
    Hint, keep it under 120 and it wont do it......
  10. K5dreamer
    Mar 14, 2005
    3,084
    Alexandria, Va
    oh goody, i get to take stuff apart :D play time!!
    oh and im a part time bicycle mechanic, so i should be able to find a few old bike tubes
  11. dyeager535
    26,980
    Before completely reassembling, make sure you can tighten it just enough.
    I can't recall for sure, but I did this "mod" so long ago, I may have had to grease the bicycle tube up a bit to allow ANY slip.
  12. K5dreamer
    Mar 14, 2005
    3,084
    Alexandria, Va
    sweet, now, i looked undernieth the mirror mount, and there is just a single allen key button head bolt. is that what i take out? or is this something where i am supposed to take the door panel off and get to the mounts on the inside of the door, loosen the nuts, remove the mirror mount, get inside it, and after repairing it, put it all back together, cuz im also having some door lock cylender problems, so i need to get in there anyway. so its no biggie. i just dont wanna do this the wrong way and screw it up, my backup car isnt running right now, and the truck is coming up on inspection.
  13. dyeager535
    26,980
    Allan screw comes out, then you slide the cover up along the arm for the mirror to access the internals/remove the mirror from door.
  14. K5dreamer
    Mar 14, 2005
    3,084
    Alexandria, Va
    haza! spank you, spank you veddy much :D
  15. dmanblazer
    Sep 5, 2004
    165
    Wellington, Kansas
    Just the mirror, not the mount that's attached to the door.
  16. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I can't recall if there is any glass still in my mirrors. The trees and rocks push them in so often I just leave them like that.
  17. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    that's usually how i can tell when i am driving too fast,,,when this happens:doah: :D
  18. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    me 2!:D
