Side Panel Photos with 10" MTX Speakers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BurbinOR, Mar 7, 2000.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Side Panel Photos with 10\" MTX Speakers
    A couple of guys asked me to post this for all to see.....eliminates the bulk of a speaker box in the back end of your rig, these 10" MTX Thunders sure pound enough for me.........not to say when I was 25 the 15" Cerwin Vega woofer wasn't the deafness-inducing speaker of choice, but in my late 30's these 10's are fine.......they are mounted in 5/8" particle board which is screwed to the sheet metal and frame.......think about 30 screws per side. Nice, solid mount, no vibrating, even with RUSH 2112 rocking!
    '79 - 406 w/IROC TPI - K5#5 - a <font color=orange>sickness[​IMG] <font color=blue>you never get enough of!! [​IMG]
  2. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    Re: Side Panel Photos with 10\" MTX Speakers
    is the speaker sealed? there's a space behind that panel, but did your buddy seal it off? or does that speaker have the entire fender of airspace?
    by the way, nice install. is that entire panel particle board? with new covering?
    <font color=purple>delta9blazer</font color=purple>
  3. BurbinOR
    5,829
    Oregon
    Uses the entire airspace behind the particle board for the "thump chamber". It is one full piece of particle board, with carpet from cheyenne pickup parts to match the rest of the interior carpet (did the whole project at once). There are no partitions, didn't need them, and though it isn't hermetically sealed to the body (there are small gaps) they aren't significant enough for me. It rocks, thumps and saved a hell of a lot of room (used to have Pyle 12's in a rather large box).
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue> that side panel looks good. how did you measure it? i want to do that to my K5 so i could have a hidden place for small things and so I couild install some speakers.</font color=blue>
  5. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    Just a quick question, do you ever take off your top? If so, did you remove the rear anchors?
    Corey
    88K5
    [​IMG]<font color=blue>Girls Like Guys In Bow Ties</font color=blue>
    <font color=red>http://www.geocities.com/corey_perez
  6. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I'm looking into a new carpet set from CPP too. How good was the carpet? Was it a perfect fit? Is that the only grey they have? How easy was installation? Any comments on it?
    Sorry for the lots of questions.
    <font color=purple>////////
    Go 79s!!!
    </font color=purple>[​IMG]
  7. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Frank, that looks really good! I have some factory panels that i dug up for free out of a junked 83 K5....figure i can duplicate your results using those as a template. Also i figure with the gallon of Herculiner i installed in the rear it ought to help with sound deadening and make some speakers work rather well. Question though..those 10's aren't aimed directly at each other are they? And 2112 is an excellant choice of tunes!
    AZBLAZER
    1979 K5
    1976 K5 Chalet
    1972 K10 Suburban
  8. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    picture of my system
    That is a nice clean install. Unfortunately I still rock out and want the seriously loud sound. Here is picture of my system. The box comes out with two screws and 4 wires but it still gives me 149db in competition and no the box is nearly impossible to duplicate.
  9. BurbinOR
    5,829
    Oregon
    Top comes off all summer as this is not my daily driver......and stays off! LOL Removed one anchor (that sheet metal U shaped holder, but if anything, this set up stiffens up the rear area with the thickness of wood I used and all the screws.
  10. delta9blazer
    1,646
    Re: picture of my system
    blueknight, that's sick.
  11. johnny reb
    johnny reb 1/2 ton status
    Mar 6, 2000
    326
    Pittsburgh, PA
    Looks good. I might have to give that a try. Do you have an amp running those subs? Where did you mount that at? Right now I have 2 12" MTX in a box, but it takes up too much room in the back. Did you have to cut any of the sheet metal to allow the magnet to fit through? Or is it as simple as cutting a piece of particle board to fit?
  12. BurbinOR
    5,829
    Oregon
    Have a Fosgate 150 watt amp running just the subs.......it is mounted behind that panel you see in the picture to the sheetmetal. I know those amps are supposed to have more ventilation and all, but I also know they are damn near bulletproof (this one is 10 years old and never a problem), so hiding it was worth the chance. No, didn't have to cut any sheetmetal, though you may have to "shim" out the speakers with a ring depending on the backspacing of the magnets>>>>>>those MTX woofs were about the best combination of quality and minimal backspacing that I could get. I just used the original wimpy side panels as a template and cut the particle board. Took my time, had to use a router to undercut back by the tailgate latches, but the time spent was well worth it.......for sure.
  13. Blazer79
    1,816
    With 140db you will start to feel pain in your ears! With 149db I don't even want to imagine. Is it at least a huge juicy price in those competitions? Let me guess... a new pair of inner ears... LOL [​IMG]
    Go 79s!!!
  14. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I sat in a buddy's car when it was hitting 165dB. Lemme tell you, it mushes up your insides and you have runs for a week. At least on me it did. Won't ever do that again. Now it's hitting 175+ dB and that is just Psycho. Can't even sit in this thing while it's cranked. NOT my thing at all, but cool to see how that stuff works. He's currently got the world record, all out of a little car with 9-15's and 18 amps. A few other friends have systems running from 128-155 dB. Mine is just one 12" sub and a small amp producing 132dB on the dash. Wild world, this car building stuff. To each his own!!
    Bryan
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
  15. laketex
    6,220
    North Texas
    And hey Blazzin, that looks really trick. I may use that idea myself. I think I'd put mine under the carpet though, a little muffled sound but with bass it doesn't really matter. And the subs would be masked from view. Looks good.
    And BlueKnight, you trying to be like Alma Gates? LOL Hey dude, it's cool, I've seen that stuff before. Does that wall fold down, or is it the full height of your truck always? Cause it looks like it folds or something in the pic...
    [​IMG][​IMG]
    Durant, Ok
  16. johnny reb
    Mar 6, 2000
    326
    Pittsburgh, PA
    What year is that truck? To me it looks like a mid 80's. Did the original panels have speakers in the rear corners by the tailgate? What did you do with them?
  17. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    sick.. well it does make you queasy, but hey I used to run a cazr stereo store. To get repsect you have to walk the walk. In this vehicle I can even walk over them :)
  18. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    Actually at those volume levels you wear aviation headphones.
  19. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    actually the speaker box lifts up hydraulically and the amp rack cover slide out. It sits about 2" above my back seat.
