Sieries of Clunks when Accelerating? *SOLVED*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SAVAGE1, Mar 22, 2002.
  1. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I recentlly developed a strange noise while accelerating from a dead stop. I get a sieres of 1-5 clunks when accelerating normally. And for some reason it tends to do it more when I'm making a left. It doesn't do it everytime but its enough to worry me. I feel the popping right under my feet.
    I've checked the following with no luck: engine/ tranny mounts, body mounts, frame around steering box, retorqued Ubolts, crossmember bolts, adapter bolts, bellhousing bolts, converter bolts, checked driveshaft Ujoints, front axle Ujoints look fine and that's about it.
    I jacked up the rear tires and inspected everything in motion. The Tcase seemed to have a lot of play in the interals. Nothing too abnormal though. At cruising speeds I don't get the sound at all, only during accelration. Did I miss anything? Thanks in advance.
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Re: Sieries of Clunks when Accelerating?
    Check U-bolt torque. My front left seems to come loose more than the others. It clunks only after I accelrate from a turn. In other words, I turn the wheel all the way to the right then accelerate, then I get a clunk or two. That is when I know my U-bolts are loose.
    Other issue could be the u-joints are too tight!
    Good luck.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Also take a look at the front spring shackles. The left one is right under the drivers feet. A bad bushing can make some strange noises under there.
  4. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    I already checked the Ubolts. And my front shackle bushing is new so I don't think its that. Thanks, keep 'em coming.
    Can a Ujoint really be too tight? Also, I had my brother shift in and out of gear while I was under the truck and I heard a clunk coming from around the Tcase. As I mentioned above the Tcase had some play. Does this sound like a Tcase going bad? Its a 208.
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    All the 208s I have had or have seen have alot of play in it. That noise is common. Did you check for excesive play in the rear end? Also do you have a Gov Lock, because if you do it sounds like its getting ready to blow up /forums/images/icons/smile.gif
  6. sarazk5
    sarazk5 1/2 ton status
    Feb 19, 2001
    713
    Sacramento, CA
    I get these noises also. Something has been causing a bad vibration. My crossmember bolts under my tranny keep comming loose. In fact popped off the other day. Today on way to work all of a sudden I had a ton of vibration... and that clunking again. i think i blew another Ujoint. But like the other guy said... if you have a gov. lock it makes those same clunks. Mine blew a couple of weeks ago. It sounded like it was popping under my feet. It ended up shooting a hole through my diff cover. Fortunately we were able to break the rest of it out and remove it... for now I have an open diff.
    Sorry if this didn't help... just sharing similar problems.
    Sara
  7. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    I blew my 10 bolt GovLoc last year. I have a 14B FF (open) under it now so that's ruled out. Basically I replaced my entire drivetrain from engine to axles except for the Tcase. That's why I suspect it to be the problem. I have a new 1Ton driveshaft and everythings tight. I'm running out of places to look and this is annoying me.
    Here's a little background on the rig: I dropped my Tcase to help with the vibes and I never had the sound. Recently I put in a new engine and tranny and when I got everything back together I left the Tcase in the "up" (stock) position. After a week of driving the truck, I droped the Tcase back down and that's when I noticed the sound. I don't know if that has anything to do with it but hopefully someone has the answer. Thanks for your reply's.
  8. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Have you checked your exhaust Y pipe hitting the front drive line or did you already extend that...Dan
  9. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    I had the Y pipe extended already, plus my front driveshaft isn't installed right now. This is really starting to bug me. I'm just about done breaking in the new engine but I'm scared to really get on the pedal with that noise there. I feel the clunk when the tranny downshifts also, like there's something loose in the drivetrain. This sucks, I'm gonna go through every bolt tomorrow.
  10. dano_nd
    dano_nd Newbie
    Mar 24, 2002
    Rod - my '90 Suburban does the EXACT same thing. The 3-2 downshift gives a "clunk" and I get the same "clunk" when I accelerate from a stop. I do know my rear-end is pretty shot, so I'm assuming it's something to do with that. Let me know if you figure out exactly what it is!
  11. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    I GOT RID OF THE CLUNK! As I was saying above, the noise developed after I dropped my Tcase. So over the weekend I put it back up to stock and the noise dissapeared. What confuses me is that I had the Tcase dropped before my engine swap and I had no clunk. I guess the rear slip yoke was binding somehow because of the angle. I just can't figure it out. Well no use thinkin bout it any more. Just gotta deal with my driveshaft vibe.
  12. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    When you dropped the t-case to check and see if your dist. was hitting the firewall....Dan
  13. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Yeah the dist. was not touching the firewall. Had to be the Tcase binding somehow.
  14. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    That's a wierd one... Usually dropping the t-case helps the angle..Dan
  15. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hmm......Something doesnt make sense....You've checked the condition of the transfer case-to-crossmember mount right? Budz '90K5 with 700R4, had a mount with pretty much no rubber left in it...Did the same thing...clunking when accellerating. A new mount solved the prob.
  16. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Yeah I was thinkin the mount, but everyone seems to be out of stock (poly urathane mounts). When I replace it I'll try to drop the case again.
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Poly there might cause vibrations to be transmitted to the body anyway. Get a new rubber one at Autozone for $18 with a lifetime warrenty. If you ever have the tranny out, take it back and get a new one. They're good about taking stuff back.
  18. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    You beat me to it 84...Was gonna say the same thing. /forums/images/icons/smile.gif
  19. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Thanks, I'll give it a try.
