Signature Series breather (NEED HELP)
Discussion in 'The Garage' started by adamforsythe, Mar 29, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I installed a edelbrock Signature Series breather on my Signature Series valve covers. And it seems like the engine is running a little faster at idle.
    What is going on?
    Adam
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you might have a vacume leak. If you started unpluging parts of the PVC system you have to plug the holes on the carb
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I did not leave anything unhooked. I just put a edelbrock pcv valve in and a edelbrock breather in.
    ADam
  4. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    PCV valve...
    Did it HAVE a PVC valve before??--if it did,and you had no breather,it would not let any air in the engine,and it would have to pull air past the rings and valve guides,instead of getting fresh air thru the breather...ever pull the PCV valve out of the valve cover and put your thumb over it with the engine running?--it should make the idle speed drop slightly if its working right--running one with no breather will have the same effect,not to mention it will suck oil into the PVC valve and burn it in the engine... :crazy:
