Signs of a bad throwout bearing
Discussion in 'The Garage' started by wayne, Apr 6, 2004.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Jeep started to act up last night on the way to work. I was driving down the road and it just started making a ticking sound. I was in 5th so I thought it might be a sign of 5th going out which the AX5 is prone to. Well I downshifted into 4th and the noise went away or at least I could not hear it. Well I cruised up 15 in forth got off at my exit and pulling up to the light I could hear it again. Pulled out and it was kinda loud in all gears but 4th. Made it to work and checked reverse and it did it. Had a friend follow me home and everytime I stopped it would get louder and louder almost to a knocking sound now. If I push the clutch in it quiets down but it is still there, also pulling out it clunks and makes a ton of noise. The clutch seems fine. It does it in all gears but 4th is not as loud and pushing the clutch in does affect it and it quiets down. Could this be a throwout bearing or what else should I look for?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think you've probably got something wrong inside that transmission. If it was the throwout bearing, it'd probably get loud when you stepped on the clutch.
    When you step on the clutch, the insides of the transmission will stop turning if you're not moving. That's probably why you're not hearing any noise.
  3. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    i think you nailed it the bearing and this is why i think that [ QUOTE ]
    [/ QUOTE ] but what is the miles on the trany and cluch
    ther is allways option 2 the 350CC and th400 D300 swap that will bring that jeep to life /forums/images/graemlins/whistling.gif
  4. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Clutch miles are under 12000. Just replaced a little over a year ago. Trans milage is unknown. Before I swap a V8 in it I will just buy some tube and start bending up my own buggy. All the Jeep is going to get is a rebuilt 4 banger/trans, D44 rear and possible front, and a mild lift and 33's. I figure it will make a good all around vehicle. The K5 is going to be the dedicated trail rig and Donna already knows it will eventually lose to the /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif. /forums/images/graemlins/woot.gif /forums/images/graemlins/ignore.gif
  5. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I had this happen on a little truck 5spd -- it was the tranny. 4th gear was the only gear without any reduction or overdrive and didn't make any noise.
  6. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Yep, I'm hearing it might be a main shaft bearing shot to hell. /forums/images/graemlins/doah.gif I'm looking for rebuild kits now. I talked to a friend of mine and he said we should be able to handle the rebuild of it. I do have a spare trans if all else fails but I don't know the condition of it. I got it for dirt and was planning to rebuild it anyhow. Looks like I will leave it be just in case I need to slap it in to try and use it. /forums/images/graemlins/dunno.gif
  7. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Be sure to check prices at Transmission Exchange Company when looking for a rebuild kit. They are a great company based out of Portland, OR and have good prices and excellent service (I have used them many times). /forums/images/graemlins/thumb.gif
