Signs of a dead tranny
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Mar 27, 2001.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i know people here have had dead tranny's
    can yall gimme some signs of one.
    i think i got one. but not sure.
    thanks
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  2. dyeager535
    26,980
    umm...have to rev it up to go in gear, or it doesn't move but the engine revs while its supposed to be in gear?
    Dorian
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    First things first. Check the color and smell of the fluid- brown and burnt smell= heat problems which are usually signs of old age, burnt clutches etc. Check the vacuum line to the modulator, if it's got one, and replace it if there's any question. Then the linkage and kickdown cable adjustments to be made. If thats all good, you will need to tear the tranny down to find out what's wrong inside.
  4. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> It will over-rev before it shifts, sloppy shifts, no shifts and the ever popular 2 letter answer ............. P U ....... burnt tranny fluid.
    L8r,
    . Riz . <A target="_blank" HREF=http://www.geocities.com/rizmonkey>http://www.geocities.com/rizmonkey</A>
  5. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    You won't move, constantly burning tranny fluid. Lots of metal shavings in pan. If fluid is burnt try changing fluid and filter. See if it helps any. Always check fluid level first with engine running.
  6. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Tranny guys smilin' with a hand full 'o parts.
    Twiztid
  7. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    Sorry to tell ya, Confederate9, but I think I hear taps playing in the distance for your tranny. From what ya said before that tranny is definitely DOA.
    [​IMG]<A target="_blank" HREF=http://www4.ncsu.edu/~brschoch>http://www4.ncsu.edu/~brschoch</A>
    My truck beat up your SUV
  8. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    im past the stage of sloppy shifts and wont shift at all. im just gonna leave it till my dad gets home and we can go have the tranny rebuilt.
    so i havent reached the stage of burnt tranny fluid.
    just letting it sit in the drivway =( and hitchen rides.
    thanks guys.
    ill keep yall posted.
    later
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    There are only three things that warrant pulling the transmission out of the vehicle:
    -Burnt clutch
    -Fried Band
    -Exploded part
    The last one means that you have to do more than just replace the blown-up part, you have to clean the metal out of every part of the transmission.
    If one of the first three conditions doesn't apply, there are many things that can be done while the slushbox resides in it's normal home.
    -Clean, rebuild, replace seal for governor
    -Clean, rebuild, replace seal for Servo
    -Clean, rebuild Modulator
    -Check TV linkage
    -Air check the operation of the servo
    -Remove and clean or rebuild the entire valve body
    -and of course, change filter and some of the fluid.
    As said before, fluid level is very important. Always make sure that it is right according to instructions (i.e. warmed up, engine idling in drive against the parking brake). Whether or not the level was correct last week or even yesterday is irrelevant.
    <font color=green>Stupid tourist at Mammoth Cave, Kentucky: "How many miles of unexplored passages are there?"</font color=green>
  10. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    It has to be in drive to check it???? I thought it was to be warmed up and in park, running.
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  11. dyeager535
    26,980
    You ahve to have it warm, but you need to shift into each gear all the way to first, then back to park through each gear, THEN measure. You HAVE to make sure the fluid is hot thoguh first...just letting it idle for a few minutes won't do it IMO...the tranny will be overfull if you don't get the fluid nice and hot first.
    Dorian
