Silicone on carb base?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jimmyjack, Aug 14, 2000.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Has anyone ever used silicone on a carb base? I've heard its a no no. I thought of using 3M window adhesive(gorilla snot). My carb is a little pitted on the bottom and its contributing to my vacuum leaks. I was hoping I could seal it up a little tighter. Please lemme know what you think.
    creepin' and crawlin'
    Jim
  2. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    they sell a special rtv sealant for parts with gas near them anything else will dissolve its only 3 bucks ,remember that regular rtv can be cleaned off with gas so watch what you use
  3. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    I would say no. If it is pitted that bad try to find another one used and use the base off of that,assume you have a q-jet. Have seen these at swap mmets for around 20-30 dollars. Not sure if they all interchange though.
  4. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Had a buddy suggest a thin film of grease, said it would fill in the pits and the rest would wipe away or get blown out the exhaust. I think he's about 100 years old and been around the block a few times so I don't think he'd steer me wrong on this. I'll let you know, thanks for the feedback.
    Jim
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    You can fill in the surface with JB Weld, before it sets up wipe the extra with a puddie knife. Then use a ulta flat b
    lock and sand paper to make level.
    Good luck
