silicone on the beads???
Discussion in 'The Garage' started by Bhintz, Dec 21, 2004.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    do any off you guys run silicone around your beads or any like that so they seat better and dont leak on the rim
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i have heard of people doing it on cheap beadlocks to keep them from leaking air, but don't know any one that has done it??
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Bead sealer?
    :confused:
  4. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    I was going to run a bead of silicone arround my rims, but not to keep the bead seated. I just hate getting my bead full of crap when im wheeling. I decided that it probobally wouldnt work very well so i never did it.
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Don't do it. If you ever want to or have to change the tire the rim will be one step from useless. It will take some heavy work to get the wheel clean enough to hold air. Ya you can wire brush it but then it will rust and slip worse than before. I am an advocate (as is harley) of reverse wheels for the ultimate poor mans bead lock. Hossbaby50 blew a bead on his 35" MTR's with 19 PSI using 15X8 standard steel wheels, I took the same line (it scoots the rear around heavily and rips the bead away) with my 15X8 reverse wheels and only 13 PSI with no problems or even a burp from my 37" MTR's.
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I hope this isnt stupid but what is a reverse wheel??
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    a reverse wheel turns backwards (read reverse) than a normal wheel
    :rotfl: :rotfl:
    the cutout for the tire to sit into when the tire is being put on is on the inside instead of the outside. the bead has to travel farther to fall inside this cutout and loose pressure
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ah ic thanks
