silicone vs copper gaskets
Discussion in 'The Garage' started by DwarF, Apr 7, 2003.
  1. DwarF
    DwarF 1/2 ton status
    Mar 29, 2001
    226
    Austin, Tx
    I had to pull my header off to make some adjustments, and now the original gasket will not seal as you would expect. In looking at alternatives, there seemed to be two far extreems to the spectrum, on one end there was the silcon that is spec'ed to 1200 deg F for 3 bucks a tube, and on the other, there was the copper gaskets that are over 60 bucks a set.
    Why would anyone pay 60 for a gasket?
    Is there any disadvantage to the silicon vs the standard paper/asbestos gaskets?
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    silicone does not work for exhaust
  3. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    I've had really good luck with soaking the plain old cheap stock manifold gaskets in warm water for a few hours and then bolting them on and letting them dry completely before running the engine.
    The first time I tried it I just went back to retorque after a few heat cycles and they never leaked.
    Now, I'll only use the plain stock gaskets because:
    <ul type="square"> [*]They work great. [*]I'm a cheap a$$ and I hate spending money. [/list]
    /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  4. DwarF
    Mar 29, 2001
    226
    Austin, Tx
    I would have normally agreed that silicon doesn't work for exhaust, but this stuff says it is specifically made for exhaust applications. I've seen the black and blue silicons for diffs, etc. But this stuff is red. Have you used this stuff and it didn't work for you on exhaust?
  5. AnthonyG
    AnthonyG 1/2 ton status
    Jan 26, 2003
    339
    Gillette Wyoming
    I use red silicon (RTV) on a lot of stuff but not on exaust
    I get a awsome set of victor rens header gaskets for under 20 bucks
  6. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    Ultra copper silicone works extremely well on header gaskets. Copper gaskets tend to leak a small amount &amp; are more suited to extreme duty race applications. The white fiber header gaskets are generally scrap as well. Try the High Performance Fel-Pro gaskets.... they are metal reinforced &amp; will hold up well. I always silicone these &amp; have never had one blow out or leak in close to 10 years.
