Silly 14bff question...
Discussion in 'The Garage' started by clubba68, Oct 3, 2003.
  1. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Is there another caliper that you can use when doing the 14bff axle swap that will allow you to keep the use of your e-brake (other than the Cadillac ElDo's?) I read that TonyP had e-brake and T-Bird calipers?
    Thanks,
    Andrew /forums/images/graemlins/usaflag.gif
  2. clubba68
    Dec 6, 2002
    1,511
    50 views and no one knows? /forums/images/graemlins/confused.gif
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    I've seen people put the disc brake setup from the late model 14 bolts on them, but don't know the details on how it's done.
    Tony has the t-bird calipers, but had to work some special magic on something or another because the calipers don't open as wide as the Caddy ones.
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    tony p used the ford calipers. he had to modify the rotor. i think he shaved a little off it. i dont remember exactly. im pretty sure he has pics of it up or will help you out with some. someone once told me you could get the entire disc brake setup off a bonneville and make that work for a blazer. I forget the year but it was the first few years that had 4 wheel disc brakes. might check that out. im assuming you searched here so check out google tons of stuff there.
    hope it helps
    69k5 /forums/images/graemlins/k5.gif /forums/images/graemlins/grin.gif
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    yep, it was alot of work...next time I would get the caddie ones...but the t-bird ones worked out great...
  6. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I don't think a lot of vehicles ever used a caliper with a built in parking brake feature. Most vehicles with rear disc brakes use a drum-in-hat setup......basically the rotor has a small drum in the center of it that goes over a small drum brake setup that's used only for parking.
  7. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Keep watching Ebay I just got a great deal on my 76 caddy calipers for 60 bucks and they work Im just gonna get them cleaned up REALLY good...
  8. clubba68
    Dec 6, 2002
    1,511
    Buying brake parts off of ebay always scares me because you can't test them or check them out hands on. Is there a way/something to check or have the guy selling them check to see if they are working or not? Do you just have to press your luck? Most ads for brake stuff say like "Pulled from a wrecked car, not sure if they work, sold as is." I would just like to know that they will work before I drop the bucks on them.
    Thanks,
  9. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    On a used caliper, you should plan on rebuilding it anyways even if they say that it is working fine. On a wear item, why put used parts on your truck?
    Also, if you can find the levers and springs for the eldo, then you can get already rebuilt calipers at Hi-Lo. It's the lever and return springs that are hard to find.
  10. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Hi angle driveline makes a nice one That goes on the rear of the transfercase.....
  11. clubba68
    Dec 6, 2002
    1,511
    Why used parts? I was unaware that they were still making new brake calipers for 1976-78 Cadillac ElDorados.
    What is Hi-Lo?
    Mudjunkie: I don't like High Angel so much since they don't return emails.
    Thanks,
  12. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Hi-Lo aka Orielly's in some states is an auto parts store. Parts America( www.partsamerica.com ) aka Advance Auto Parts (website named accordingly) has the 76-78 caddy eldo calipers unloaded for about $75 bucks each with a $10 core. This is the best price I have found for them. Napa has them for $70 but with a $70 dollar core. I am on my way out to a junk yard right now to pick up some levers and springs. The guy said he had several out there /forums/images/graemlins/thumb.gif so you may see some up for sale if my friends dont snag them from me first.
