Silly hub question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bking, Mar 21, 2001.
  1. bking
    bking 1/2 ton status
    Jan 4, 2001
    176
    Alaska /Here from Ireland in Dec 2000
    ok, ok, I'm new to this............
    When I shift my 85 K5 into 4Hi, is it in 4 wheel drive even though the hubs aren't locked?
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    No, shifting to 4 Hi engages the transfer case so that the front axle is driven (front drive shaft will turn) but the hubs are not locked so the tires receive no power.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  3. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Do you have auto locking hubs? If so yes. (as long as they are working) If not no. You have to get out and lock the hubs.
    When all else fails... Check the blinker fluid.
    78 K-5
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    When he said "even though the hubs aren't locked" I took that to mean manual hubs. Maybe not...
    Hmm, were autos even available on 85s? I'm not sure when they started using them.
    Bad Dog
  5. bking
    Jan 4, 2001
    176
    Thanks guys, I'm in Alaska and have only been here about a year, (From Ireland) experiencing my first winter, I have been driving in 4Hi, (Manual) hubs locked, and now there is a bit of a thaw and the roads are dry. So, I unlocked the hubs (Which alway shuddered when I was turning sharply) but left it in 4Hi, thinking I was still in 4WD nearly had me causing a wreck the first ice I hit......Maybe I'll leave the hubs locked just another week or so hahahaha Thanks again.
  6. StoneyK5
    StoneyK5 1/2 ton status
    Jan 4, 2001
    472
    Birch Bay, Wa.
    Hey, bking, why don't you just lock your hubs and drive in 2Hi until you need to lock in, then just pull the shift into 4Hi. This is the way I do it and I drive 20 hwy mi each way to work, and I can shift at 40mph no prob. I have Warn Prem hubs, also. Just a note, when you unlock the hubs, the truck should be moved back and forth to make sure the hubs do unlock and not stuck. my .02
    83K5 Silverado
    What was that bump?
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I had autos on my 84
    Murphy's Laws on Life :
    "It is a mistake to allow any mechanical object to realize you are in a hurry."
