Silly Hydroboost fluid question of the day!!!
Discussion in 'The Garage' started by Xtremjeepn, Apr 2, 2007.
  1. Xtremjeepn
    Xtremjeepn 1/2 ton status
    Jan 17, 2006
    437
    Saddle Rock, CO
    What fluid do you run in it?
    Here is the basis for the question. I just took the pump out of this truck I am building and it was full of brake fluid, not power steering fluid. :confused:
    Just got a new pump. What is the best fluid to run?
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Uhh, brake fluid in the power steering system? Mighta been some kind of generic hydraulic fluid.
    or your PO was a dork. ;)
    Should be PS build, or maybe ATF, in the PS system, including the hydroboost pump and booster proper.
    Obviously the master cylinder should have brake fluid in it.
    -- A
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I run PS Fluid in mine. Brae Fluid can eat the seals in the pump and there are arguments over running ATF due to moisture concerns.
    I dont know any of it and since it comes from the PS pump I run PS Fluid.
    Ira
  4. Xtremjeepn
    Jan 17, 2006
    437
    Saddle Rock, CO
    That's what I thought. Probably explains why the pump was leaking the way it was. Got a whole new unit with resvoir. Thanks guys.
  5. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    I use Valvoline's synthetic p/s fluid. I've read that the GM brand fluid is the best, but it's freakin' outrageously priced.
  6. 5280k5
    5280k5 1/2 ton status
    Dec 18, 2005
    1,175
    Aurora, CO
    Not when you get it for free;)
    We even have a special formula winter power steering fluid:
    Cold Climate Power Steering Fluid
    Size:Item #:16 oz.1234586632 oz.12345867
  7. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Sweet, I love free stuff, where do I pick it up at??:D
