Silly question but....
Discussion in 'The Garage' started by mtrdrms, Apr 13, 2005.
  1. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    I just got another 87 K5 this weekend and I was changing the oil and filter. After I put in 5 quarts I started it for a few minutes and then let it cool and checked the level. It shows I need to add another quart? Did some 5.7 FI motors come with a 6 quart pan? Is there a way I can tell if the pan is a 6 quart? I am skeptical of putting in another quart because maybe the dipstick is off of something I dont know. It is an 87 with the 350FI, 4x4, 700R4. Thanks
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    truck was level right?
    also how big was the filter?
    some from different man. may be different sizes, the one i put on my truck holds 1/2 quart, i always fill the new one before puttin it on
    a little anal i know but hey whatever :D
  3. mtrdrms
    Mar 14, 2005
    312
    Torrington, CT
    Yeah it was level. And it was the same filter I took off - Pure One, half quart.
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    hummm i run 5 in mine with no problems, 89 350
  5. mikayak390
    mikayak390 Registered Member
    Mar 3, 2005
    70
    NJ
    I always use 6 quarts, It actually takes 5.5 to hit the full line in mine, and the rest is only a little over so I just dump it in. No problems that I know of. Besides I have a slow leak in a rusting cooler line. I figure that makes up for what I loose over two months.
  6. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    350 should have a 5 qt pan, 1/2 quart filter and 1/2 qt of lines that remain filled after your oil has settled.... I just had the same question when I was puting in my engine and 5 quarts of oil showed 1 qt low ont he dipstick.
  7. mtrdrms
    Mar 14, 2005
    312
    Torrington, CT
    well I contacted the previous owner and he said that he has een putting 6 quarts in the thing for the last 15 years so I guess thats what I will do. Anyone ever heard of a stock K5 with a six quart pan?
  8. dyeager535
    26,979
    Don't think they used a six quart pan on the Blazers.
    How about an oil cooler? Have one of those? They are not *supposed* to go "dry" with sitting, that should hold more oil too.
  9. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    It's a 5 qt pan... but the filter holds a half quart...
  10. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Interesting...My 90' Burbans 350 takes 5.5qts and always has.
  11. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Is there a chance that the dipstick or tube are not original equipment?
    Do a quick dipstick check with another truck 350....?
  12. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    watch it that's how my last 350 blew up.
    adam
  13. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Mine's a stock '87 with a factory oil cooler; it takes 6 quarts to get to "FULL" on the stick.
