silly question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Dan, Jan 25, 2003.
  1. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    ok ive got a 208 transfer case.problem is i have to fill it with tranny fluid to often.it's leaking from rear output shaft /forums/images/graemlins/confused.gifdo i just take driveshaft off andpry out the old seal.i know i know what a moron. /forums/images/graemlins/thumb.gif
  2. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    that's not a stupid question at all, i don't know the answer, i'd like to know as well.
  3. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    correct..................on both accounts /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  4. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    thanks /forums/images/graemlins/confused.gifI think /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  5. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Yeah mine does the same thing and its not the seal. Id like to know what the problem is, my boss said its some bushing inside.
  6. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    have you replaced the seal? /forums/images/graemlins/eek.gif
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You can go ahead and try and replace the seal. It isn't hard. Remove the driveshaft and pop the seal out. A seal puller is the best and easiest way. I used a BFS (Big freakin screwdriver) to pry mine out. Probably not the best way but it worked. Unfortunately this probably won't solve the leak problem. It didn't solve mine. I forgot what they say it is but I have just gotten used to the leak and I fill it when I remember too.
    Harley
  8. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    thanks i happen to have a BFS guess i'll put it to work or vice versa /forums/images/graemlins/thumb.gif /forums/images/graemlins/eek.gif
  9. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Most times it's the seal but if the new seal doesn't fix it, you need to change the bronze bushing as well. Or chek you yoke for a grove, if there is a grove you need to either change it or resleeve it.
  10. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    What does replacing the bushing entail. My boss says he doesnt want to get into it and wants me to take it to his friends tranny shop. Im thinkin he just doesnt want to help me with that job. /forums/images/graemlins/shocked.gif
  11. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Assuming you have the 208, you have to take the tailhousing off and push the bushing out and then press the new one in, and put back together.
  12. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Actually I have the 241 /forums/images/graemlins/grin.gif
  13. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Ok unbolt the 4 bolts holding on the tail housing and inside you will see the bushing. Your going to want to have something that can push out the old bushing without tearing up the mounting surface. When you get the old one out just press the new one in nice and evenly. Replace the tailhousing and use RTV on the mating surface between the tail housing and T/C. Make sure everything is back together and ready to go and slide the shaft in and make sure it isnt scored at all. Mine was scored pretty bad and I used a angle die grinder and some fine emory cloth to get out most of the marks. Hope that helps ya out some. /forums/images/graemlins/thumb.gif
  14. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Thanks man, now maybe I can convence my boss to give me a hand. Yeah right
  15. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Sounds good on bushing and seal fix.If you ever replace slipyoke look for one out of 205.It uses 1350 series joint. /forums/images/graemlins/thumb.gif /forums/images/graemlins/truck.gif
