Silverado pressure baffles are baffling me
Discussion in 'The Garage' started by w0lf, Jan 7, 2007.
  1. w0lf
    w0lf Registered Member
    Jul 4, 2004
    57
    San Jose, CA
    hi,
    i did a quick search on this, but didn't see it covered anywhere else.
    i took the rear seat out of my 2005 2500HD Ext. Cab so my dog has somewhere to ride with me when it's cold / raining out. what i've noticed is that there is a lot of road noise in the cab (it sounds like the passenger pop out window is open). i took the truck back into Chevy, and they told me that they REQUIRE the rear seat to be in in order for the pressure baffles to work correctly, and that the noise was caused by one being stuck open. Apparently, the baffles don't operate correctly without the pressure / support of the seat against them? Right now, i have a heavy duty moving pad hung from the 3 "hangers" behind where the seat is. My thought was to cut out a heavy piece of plywood to put underneath the moving pads and press up against the firewall to provide that pressuse, and bolt it in place using the seating brackets?
    Just one problem, the sound is still there after they "fixed" it.
    What do you all think?
    Thnx
    wolf
