similarities between a rear 60 and front?
Discussion in 'The Garage' started by BranndonC, Feb 14, 2006.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    If I am reading your ? the right way, the front and rear are almost the exact same, except front D60's have seals under the carrier bearings to keep crud outta the diff, rears dont because the gear oil has to run down the tubes to the wheel bearings.
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    yeah, i'm just wondering which parts (seals and junk) i can use in my front axle that are also used in the rear
  4. eagle mark
    eagle mark 1/2 ton status
    Nov 18, 2004
    3,289
    North Idaho!
    Probably no seals. The cover gasket is the same.
