simple brake question...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by One_Ton_k5, Mar 26, 2003.
  1. One_Ton_k5
    One_Ton_k5 1/2 ton status
    Jan 30, 2003
    168
    St Paul Minnesota USA
    I got a red brake light in my 89 k5 almost all the time now and I have been using a small amount of brake fluid at a steady pace.
    I visually checked my brakes at the wheels and all seems well there but there is leakage from the master cylinder where the two bolts bolt on to the big round thing. (technical talk) /forums/images/graemlins/smirk.gif
    I figure I need a new master but I just thought i'd ask in case there is something else I could do. (like a new gasket?)
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Sunds like you are loosing the rear seal in the master cylinder. I am not sure if you can buy rebuild kits or not. But your cylinder is definetly going.
  3. sunshineoffroad
    sunshineoffroad Registered Member
    Feb 15, 2002
    11
    Escanaba Mi.
    Master Cyl's are cheap. i would just go for a new one. Two things you don't wanna skimp on are steering and brakes... Just my $.02 /forums/images/graemlins/thumb.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    big round thing is the booster and if its leaking there then you need new master cylinder
  5. One_Ton_k5
    Jan 30, 2003
    168
    Yea thats what I figured. Thanks guys.
  6. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I maybe wrong about this, but I think that red light is connected to 2 things, the parking brake and the dividing network. If the dividing network had shut off the front or rear brake system due to a problem in either system, you'd feel it, plus see a pretty bad leak somewhere.
    Or, maybe the parking brake switch isn't contacting anymore. Check that switch under the dash and make sure it is being depressed when the parking brake pedel is release (up).
    Still, it wouldn't be a bad idea to replace that leaky master cylinder /forums/images/graemlins/grin.gif
    Eric M.
  7. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    If the master cylinder is leaking, time for a new one. With respect to the red light, try this. Carefully unplug the black box next to the master cylinder. Turn you ignition sw to on, do not start, and leave it on for 15 to 20 sec, turn the ignition off,reconnect and see if that clears the red light.
