simple D60 ?
Discussion in 'The Garage' started by ryoken, May 13, 2004.
  1. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    after checking the axle I.D chart i'm uncertain of the differences visually between a 44 and 60. search feature has not been working well for me..
    going to check out a truck with a supposed 60 in the front. want to make sure its not just a 44 with 8 lug conversion... is it just a larger hump in the cover for the larger ring gear? anything else i should be looking for? thanks...
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Looks for Kingpins instead of balljoints.
    Look for 60F in the lower right of the diff housing (on the cover side of the diff)
    Look at the passenger side of the diff. there should be 1 ubolt and 2 bolts holding the springplate to the axle.
    2 ubolts= bad
    44= bad
    balljoints= bad
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    thank ya kindly sir, preciate that.. /forums/images/graemlins/thumb.gif
  4. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Also the steering arm on the left side will have 4 bolts holding it on instead of 3 bolts as the dana 44's use.
  5. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Not always...my '69 dana 44 with closed knuckles and drums has 4 bolts holding it on. I know they aren't that common, but remember...stay away from anything with front drums except Napco axles, and sell them to collectors...lol. Here is a crappy shot:
    [image]http://67-72chevytrucks.com/vboard/attachment.php3?attachmentid=70569[/image]
  6. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    The tale tale sign would be look for the absence of a ubolt on the inner right front spring plate. Dana 60's bolt on in this location and have a u-bolt on the outer spring plate holes.
  7. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Heres a good pic of my 60, you can see what everyone is talking about.
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    turned out to be a 14bff/44 with 8 lug... thanks for the insight fellas...
    no rot, yeah ok.... i'm getting tempted to have a rust-free western truck shipped in... /forums/images/graemlins/frown.gif
