Simple, Frame is cracked :(
Discussion in 'The Garage' started by sho_shane, Jan 12, 2007.
  1. sho_shane
    sho_shane Registered Member
    Dec 27, 2006
    51
    Leonard Tx
    Ok well I have the crack:( You know the one at the front where the steering box is. Heres some pics. I just took them today. But to me it looks like the crack splits on the side and runs under the box. How do you guys think I should fix it?
    I was thinking of welding it up, grinding it smoth again. Then taking something like 1/4in steel and welding on top, botom and the side under the box. Then buying the brace so it dont happen again. What do yall think about that?
    Also To me it looks like the frame is bent in? I mean the bumper fits closer on the driver side then it does on the pass said. Again just let me know what yall think.
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    id heat it then weld it, then weld the plate over it...
  3. goldwing2000
    goldwing2000 Guest
    That's a gnarly one. Definitely seen worse, though.
    Get the weld-on brace, follow the instructions to repair your frame, then get the bolt-on brace to help keep it from happening again.
    If the cracks travel beyond the area of the weld-on brace, V out the cracks and do as you said previously (weld, grind, plate) on the remaining areas.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Dude it's FRAME not fram
  7. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Yeah, I thought this was gonna be about oil filters again :haha:
    -- A
  8. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
    you will need both frame plate weld on kit and a bolt in kit. then some time with the grinder and welder and so on. thats not a easy fix one in a 1/2 hr or so. all i can say is wow. :eek1:
    note to any and all people if you need at or more than 1/4 turn in the wheel till steering moves then check the frame and linkage parts. that is all.
  9. TLCOR
    TLCOR 1/2 ton status
    Aug 16, 2005
    333
    At ya mama's!
    Could be worse. :)
    Strip the present area for paint, drill out the crack ends (if the crack(s) stop halfway), grind a V-notch throughout the crack, crank your welder way up and run a bead along the notch, lastly you should brace and plate the endangered area.
  10. sho_shane
    Dec 27, 2006
    51
    Leonard Tx
    Im just going to sell it. :(
  11. sweetk30
    Nov 1, 2004
    25,552
    545
    its not that bad you can fix it. 2-4 hrs time with some tools. :D
    you can do it :bow:
  12. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    Don't you know it's illegal to sell crack? :haha:
  13. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    FWIW and with no disrepsect to ORD, Autofab, to the best of my knowledge, is the originator of that part.
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    AutoFab actually holds the patent to it. when Tim's Offroad was selling them, that's where he was getting them from.
  15. goldwing2000
    goldwing2000 Guest
    :rotfl: Ha!
  16. blazeonchevy
    blazeonchevy 1/2 ton status
    Jan 13, 2006
    401
    san antonio tx
    that is definatly fixable.. ill see if i can link my thread about it. i think there was some good advise in it. lol.
  17. blazeonchevy
    Jan 13, 2006
    401
    san antonio tx
  18. sho_shane
    Dec 27, 2006
    51
    Leonard Tx
    Man seeing your fram makes me have tons of hope lol :D
    I cant wait you become a member.
  19. sho_shane
    Dec 27, 2006
    51
    Leonard Tx
    Would it be ok to drive it about an hour down the road to my buds house for welding?
    And again should I build some plates for the side under the gear box for suport or not?
    I would like to weld it up, then take some 1/4in steel to the top and under where the crack was. Then pull the gear box off and weld a 1/4in plate over where the gear box mounts and drill new mounting holes for extra suport. Now if I do that it will put the gear box 1/4in over, will that mess with my steering or anything?
  20. sho_shane
    Dec 27, 2006
    51
    Leonard Tx
    Update
    Well got out side this morning and yanked the front end off my truck. Its not near as bad as I thought it was. I have a friend coming over hopfully this weekend to weld it up. Heres some pics of my truck the way it sets as of 3:00pm today :D
