Simple front driveshaft question
Discussion in 'The Garage' started by stoney126, Aug 5, 2006.
  1. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    How do I get it out? it's ok to laugh. It's a 205 I unbolted the 4 bolts that connect the driveshaft to the case and the 4 nuts at the ujoints at the front of the shaft. The front poped out fine but cant get the back to come out.
    Do I have to press out the caps on the ujoint to get it to come out?
    Sorry for newbtastic questions
  2. bigredblzr
    bigredblzr 1/2 ton status
    May 9, 2003
    151
    NORCAL BABY
    You unbolted the ds from the pinion, and unbolted the rear of the front ds from the t-case and it won't come out??? I say give it a tap-tap-taparoo with a BFH or a crow bar.
  3. SchnorrCS
    SchnorrCS 1/2 ton status
    Oct 11, 2005
    368
    Loveland, CO
    x2. Mine came out with a wiggle or two. Sometimes that slip joint will seize up a little and that will make it stick. BFH it to get it out, take out the ujoints, put a breaker bar throught the ujoint eyes on each end. Stand on 1, pull on the other. It'll break loose.
