Simple question I THINK?? HELP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CaveBlazin, Jul 26, 2003.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Ok Im trying to push the blazer on the driveway but it will only go backwards I try and try to push the beast forward no joy. Is it the E-brake or WHat...... /forums/images/graemlins/thumb.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    take it out of gear...LOL, if it will only roll backwards but not forwards..its possible you just cant push hard enough by yourself to overcome the way the gears are meshed in the diffs...get some help..or jack up the rear and try..
  3. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    THANKS gonna try again Ive got help here we were watching the back tires slide on the grass as we were pushing this heep of metal
  4. Confedneck
    Nov 1, 2002
    5,236
    pull the trans out of park??
  5. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Its a manual tranny.....
  6. Confedneck
    Nov 1, 2002
    5,236
    out of gear then..
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    jack up front and try to turn both wheels and then try the back wheels too, and if its in neutral and all four wheels turn fine off the ground then its gonne be tranny or case problem i suspect. maybe chain in the case is off and wrapped around the gear in one direction and wedging when you move truck forward,
    do you have 208 or 203 casE ?
    if neither then never mind.
    giood luck
  8. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Well I think its in the axles cause I jacked the rear up and the wheels will turn backwards but not forwards. And its only on one side. The drivers side is the problem HELP!!!!
  9. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    why didnt you give me a call? is it off the grass?
  10. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Pull off the wheel and the drum on the side that locks up, and dial back the brake adjuster a few turns. reversing tightens this thing and causes your wheel to lock. Probably need new brake shoes /forums/images/graemlins/thumb.gif
  11. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    mine did that when my govloc gernaded if you have one I bet thats what it is
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    14 bolt ?
    well, if both hweles are off ground and even if tranny is in park or tranny iin gear one wheel could possibly turn but not the other one, but with one wheel off ground and other not off ground and with tranny locked then the wheel off ground should not turn,
    but tsting for all that isnt gonna help in this case, i would drop the driveshafts off the axle yoke ends and then try the axles and rule them out. gonna be about the only way to find out or possibly be able ot move the truck from where its sitting currently
    driveshaft disconnection
    good luck
  13. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Ok here's whats happening, I jacked up the rear and I can turn the passenger side wheel with ease but I can only turn the drivers side backwards. I have'nt tried taking the wheel and drum off yet But that will be next. Maybe this will help explain things better. Thanks so far for the help
  14. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    I yea and its my old 10 bolt Im putting in the 14ff or trying to hehehe
  15. Confedneck
    Nov 1, 2002
    5,236
    just jack it up, pull the cover and shafts, pull the carrier and pop the ring gear off...put the empty carrier back in and axles, and push it
  16. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Im hoping I want have to do that. But thats my last resort. I still gunna bull the drums first on the drivers side. This is [I love Jeeps] pissing me off ( I hope the censors are still working)
