simple Question
Discussion in 'The Garage' started by nstarry, May 21, 2004.
  1. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    how do you shorten an axel shaft, I am thinking of going with rockwells and the front is longer and i get shortining the houseing but the shaft itself seems tuff( strenght issues,balance,ect.)hows it done ??? can I do it with alittle time and thought?? has sombody done it ?? thanks for any input
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    only a machine shop could do it. & then you are limited to how strong they will be. the axle has to be annealled to cut the splines then hardened again so u can run it. material is weakened the more times it is hardened. axle srength will always be an issue.
    u can oder axles in any spline & diameter & length u want. this is what most people do.
  3. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    so i can order 7 inch shorter axels for 2 1/2 ton toploader never would have thunk it thanks /forums/images/graemlins/thumb.gif
