SImple wiring questions
Discussion in 'The Garage' started by Jrgunn5150, Feb 11, 2007.
  1. Jrgunn5150
    Jrgunn5150 1/2 ton status
    Nov 26, 2005
    232
    Cleveland, Oh
    Ok, I have an 87 V10 Pickup, and the wiring is a mess. It's been converted to a carb, cut and spliced to hell and back, and I'm a wiring idiot. The problem is it has the factory electric pumps in the tanks, with a regulator for the carb. I also put a one wire alternator on it. So I now have no place to hook my choke up to. I tried to run it to the fuel pump, but that caused it to open and close erractically, and the fuel pumps to run intermittently as well. But it's the only switched 12v source I could find on the fuse block.
    So what if I hooked up 2 relay's, one for the choke and one for the pumps. Would the relays make it draw less current through the block, and run both the way they should run again?
    I have a new harness for it BTW, but it's gotta wait until spring cuz it's my winter driver.
  2. Jrgunn5150
    Nov 26, 2005
    232
    Cleveland, Oh
    No one has any idea if a couple relay's can be run off one fused block to reduce the draw through that fuse?
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,924
    336
    Fort McMurray, Alberta
    It may sound crazy, but there is a wire you can tap into on the wiper pump for an electric choke. I do believe it is the white wire on the bottom most connector that is a switched 12V source...
    Otherwise, you can patch into the fused ignition post on the fuse block on the inside of the truck with a typical female spade connector. Whichever way you do it, you need to make sure it is fused, I've seen a couple trucks go up in smoke when a choke wire burnt up...
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Yes, you can use 2 relays.
  5. Jrgunn5150
    Nov 26, 2005
    232
    Cleveland, Oh
    Thanks guy's, like I said, I'm electrically retarded.
