Since no one is in the audio...help please.
Discussion in 'The Garage' started by THISISWEIRD, May 2, 2007.
  1. THISISWEIRD
    THISISWEIRD 1/2 ton status
    Mar 10, 2007
    165
    WV
    I'm putting speakers in the door of my blazer (manual windows).
    To run the speaker wire do I just use heavy gauge wire and run it with some give across the door jamb? Or should it be encased in some sort of tubing? What should I use to seal the holes in the door and in the body....just some rubber grommets?
    I was thinking about bringing it into the truck just below the door jamb switch. Anyone have better ideas or pictures of what their's looks like?
    Thanks,
  2. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    I take it you dont have power windows... The power door/window rigs have that rubber tubin thing inbetween the door and the cab pre- installed. If you can find that part somewhere you can just cut the holes and rivet it in...
    heres one with the boot cut in half...
    http://coloradok5.com/doorhingepins/10.jpg
  3. THISISWEIRD
    Mar 10, 2007
    165
    WV
    Good idea. I'll find one in the junkyard or order one from LMC.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Drill hole in door and body , insert grommet in each , use just big enough to allow wires with heat shrink on them to move with door , put heat shrink on both wires together as one conduit , drink a beer and your done with it looking pretty clean :thumb:
