Since this is the Center of Gravity...let's get some vehicle weight's.
Discussion in 'Center Of Gravity' started by yunit, Dec 18, 2003.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Since this is the Center of Gravity...let\'s get some vehicle weight\'s.
    I am looking to lighten my truck enough to not have to tow it with a diesel or big block truck.
    Ok, let's add up the weight, you guys fill in the blank's.
    Original Vehicle Weight = 4,379
    Original Equipment:
    Blazer Tub = 2000(top, doors, tailgate)
    Blazer Frame = 500
    350ci = 500
    TH700r4 = 100
    NP208 = 75
    10 bolt front = 300
    10 bolt rear = 250
    interior = 300
    tires = 50 a piece or 250 for all 5
    springs = 50 each
    4375lbs
    Added goodies:
    TH400 = 100+/-
    NP203 Range Box = 75
    Np205 = 150
    14 bolt ff = 500
    Dana 60 = 600 (with sleeved tie rod, hydro, and crossover stuff)
    42x15x15 TSL's on steel wheel's = 150 per corner...750 with spare
    High Angle Driveshafts = 90 for both
    Cage = ???
    future plate crossmember = 100
    added weight:
    np205 = 150
    14 bolt ff = 250
    dana 60 = 300
    tires & wheel's = 500
    driveshafts = 40
    1340lbs
    Lost weight so far:
    doors = 150 for both
    top = 300
    tailgate = 125
    575lbs
    So right now my truck weighs around 5000 & 5500lbs give or take. /forums/images/graemlins/tongue.gif
    Dump the body and I at around 4000lbs...not too bad.
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
  3. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Re: Since this is the Center of Gravity...let\'s get some vehicle weight\'s.
    Better question for ya. Whats the unsprung wieght of the back of a blazer?
  4. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    6000 lbs in this form. Still without 10000 Warn and something small.
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Peter,
    Don't get me started!!! /forums/images/graemlins/grin.gif
    I may have to reveal my secret desire to remold my front fenders and hood in carbon fiber, and the all-titanium multilink suspension. An all-aluminum motor could save a few pounds too..... /forums/images/graemlins/cool.gif
    I'm actually QUITE serious about the carbon fiber stuff. I think the concept of making a fullsize K5 "light" is a hopeless cause, but at least I can have some influence on WHERE the weight is carried (like as LOW as possible)
    The part of your plan that I think is going to "get you" is how much it will cost to remove weight. Unless you are willing to simply butcher the whole truck down to Toyota sized proportions....finding lighter parts to replace heavy steel ones will probably cost a LOT more than just buying a decent used tow rig.
    If really feels like a "zero sum" game too. You fight for every pound you can lose, but then swap in a heavy roll cage, larger axles, heavy wheels/tires, a 2nd transfer case, etc, etc. It almost seems like a victory just to keep the weight from INCREASING..... /forums/images/graemlins/thinking.gif
  6. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Greg72, I hear you there. If you can keep your modified offroad blazer with lift, large tires, winch and rollcage to come in at factory weight you are doing pretty darn good in my book. Mine is going to end up a fat pig!!!
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Greg, ya forgot the helium filled tires! /forums/images/graemlins/wink.gif
  8. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Original Equipment:
    Blazer Frame = 500
    350ci = 500
    TH700r4 = 100
    NP208 = 75
    10 bolt front = 300
    10 bolt rear = 250
    interior = 300
    springs = 50 each
    4375lbs
    Added goodies:
    TH400 = 100+/-
    Np205 = 150
    14 bolt ff = 500
    Cage = ???
    added weight:
    np205 = 150
    14 bolt ff = 250
    dana 60 = 300
    driveshafts = 40
    1340lbs
    Lost weight so far:
    top = 300
    tailgate = 125
    575lbs
    OK, a few numbers look artificially high to me. The hard top i have weighed personally and it comes in at 188 lbs with sldier windows...p[rolly 10 lbs lighter with solid glass.
    The Blazer tub itself cannont weigh 2000 lbs.
    I swapped the rear half of a Blazer onto my truck (the entire bed portion) and me and another skinny guy had no trouble picking it up and walking it inot a cube van. Weight for the bed portion coudln't be more than 300 lbs.
    Someone else posted the half cab portion weighs about 75 lbs. Doors are about 80 lbs each, tailgate about 120.
    Now we're left with the front floor and firewall and I don't see that weighing more than 200 lbs.
    Front clip:
    Hood ~75 lbs
    fenders ~ 25 lbs x 2
    core support ~ 50 lbs.
    My best guess is 1030 lbs for the body itself.
    I'm with Greg...just happy if it doesn't get heavier than it already is.
    Rene
  9. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    Actually when I use the term "Blazer Tub", I mean the entire K5 shell with the complete interior.
    I think that it is going to be a better idea to just buy a tow rig and heavier trailer.
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    4000 or 5000 isn't going to be that much difference in towing. Add in 1500 or so for a trailer and gear (if your lucky) and your dealing with 5500 or 6500, not worth the effort as far as towing goes. Either one will be a pig towing without a diesel (or healthy BBC).
  11. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Well, the 'guts' aren't going to weigh more than 400 lbs...
    I'd love to see Russ scale his truck, with no body to speak of I'd guees it's still a heavy pig.../forums/images/graemlins/smile.gif
    Rene
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, I need to get that done. My guess is your right! /forums/images/graemlins/eek.gif /forums/images/graemlins/laugh.gif
  13. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Mine runs about 5200# without me in it, with full fuel and minimal gear. It could be built a lot lighter if that was my plan from the first but it wasn't so it's heavy.
    My bro's tube chassis comes in around 4000-4200# depending on how you weigh it, with the 350/350/doubler/D60/14B drivetrain. It does have a link and coilover suspension that's heavier than most leaf setups.
    I really don't think you can take a full body K5 on the trail with 1-ton drivetrain and big (40"+) tires under about 5500#. If you do you're going to be trading something off, drivetrain strength (your 241 chain isn't bulletproof), chassis strength, body protection, etc.
    If you want light, ditch the whole body and build a buggy on the frame, or maybe put a S-truck on it, but those aren't even that light.
  14. CK5
    May 19, 1999
    21,625
    702
    CO
    Just curious, what does Beck's weigh?
  15. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    about 4300#
    This is with the HEAVY steel beadlocks, 42's, Doubler, D60F, etc. I think it was about 3700-3800 with the 208, D44 and 36's.
  16. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    Any pics of beck's rig?
  17. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
  18. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Hey, easy on the steel beadlock criticisms. /forums/images/graemlins/rotfl.gif They are cheap (thanks to you) and the plates are light enough to check on Northwest. /forums/images/graemlins/wink.gif Just make sure to keep the bolts tight. /forums/images/graemlins/thumb.gif
  19. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    moved to towing forum, now go tlk about 4 linking your toilet for those violent times during the holidays. /forums/images/graemlins/rotfl.gif
  20. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hey guys, lets keep this on topic. This is not really the place to talk about towing in general, there is a forum for that too. This thread is kinda marginal anyway based on forum guidelines, but I figure modifications to save weight, affecting the CoG, and understanding give and take with weight of specific components makes me think it belongs. At least for now...
