Single 3" or dual 2 1/4"?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLUESMAN, Oct 28, 2001.
  1. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Single 3\" or dual 2 1/4\"?
    What does everyone think would produce more torque:A single 3" muffler and tailpipe or dual 2 1/4" mufflers and dual tailpipes?This will go on a non-cat truck.Oh and running Hooker headers.
  2. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    Re: Single 3\" or dual 2 1/4\"?
    If its a 350 i would say 2 1/4 in duals, if its a 454 i would go with 3 in duals, just my opinion, i happen to have headers, no cats, and 2 1/2 in on my 350, i definetly like the torque it makes.
    <a target="_blank" href=http://www.bigredjimmy.iwarp.com>http://www.bigredjimmy.iwarp.com</a>
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I got 21/4" duals on my Jimmy, and I like them alot. If your truck doesn't need cats, then I assume duals isn't a legal issue. I would go duals. They only reason I would run a 3" is if it was illegal to run duals. (oh wait, they're illegal on my truck. oops).
    My Chevy isn't broken, its just out of gas.
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I reecently installed 2 1/4" duals with Super Turbo mufflers(stock exhaust manifold and no cats), and can honestly say that I noticed a pretty good improvement in power and gas mileage.
    <font color=blue> NEVER FORGET, NEVER FORGIVE, NEVER SURRENDER<font color=blue>
  5. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Ok, I've got a question for your question! [​IMG]
    What HP are you making (even a guesstimate)?? The reason I ask is that I'm having my 350 rebuilt and will be adding a new Crane Cam; Flowtech Afterburners; etc and also running a full dueal exhaust. I contacted Flowmaster's tech line &amp; they told me that if the engine wouldn't make over 250Hp then 2 1/4 is fine BUT if my engine would be making in excess of 250HP (which I'm pretty sure it will); I should go to the 2 1/2" duals cause 2.25" would not allow the engine to breathe freely over the 250 HP mark!
    Just something to consider
    Good Luck
    Brian
    89KBlazer
    Build it Right or Don't build it at all!!
  6. Can Can
    15,552
    136
    Good info, Brian........Would it make a difference if you weren't running cats? I'd hate to think that I'd have to shell out for new exhaust when I eventually upgrade my motor.
  7. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I run full length headers into 2 1/2 pipes, into a Flowmaster Y, into a 3" big block Flowmaster (not sure of the "series" #, but the case is around 22" long), then finally a single 3" tailpipe in the stock location on the passenger side. I'm real happy with it, nice tone but quiet too. A single exhaust is generally better for low end torque. It is legal for me to run a true dual on this truck, and I actually bought the parts to do it, but changed my mind and went this route, and sold off the other stuff. Glad I did.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  8. Brian 89KBlazer
    779
    Ontario, Canada
    Hey CanmoreK5
    I told the tech that I planned to run dual cats but he seemd to ignore that info. He was more focused on the HP numbers. When he said dual 2.5"; I questioned him on the exact point Pete made; low end torque. I asked about the dual 2.5" providing sufficient backpressure for good low end torque &amp; he still maintained that the 2.5" was the size to go with. Like you; until I made the call; I was planning on 2.25" but now I think I'll go with the 2.5".
    I got a price for Cats on Friday &amp; for a couple of free-flow cats; it'll cost me about $148 (Canadian) each! That'll put me at $576 for 2 cats &amp; 2 Flowmaster 50 Series Deltaflow mufflers! I'm considering skipping the cats for now &amp; if I get busted; I'll get the cats then. I've talked to a number of locals &amp; no one has heard of anyone being busted for no cats yet!!
    Oh the money!!!
    Brian
    89KBlazer
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I got a 300HP GM crate 350 with 2.25" duals and it runs fine. The exhaust doesn't seem restrictive at all. I know it sure flows better then the factory exhaust did on this motor.
  10. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Single exhaust is generally better for low torque, and one of the reasons is the exhaust pulses are evenly spaced helping to "pull" exhaust gases out of the chamber (not needed at high RPM). If you install dual exhaust, try to put in a crossover (a.k.a. "H" pipe). In a 4wd it is kinda tricky, I had to put mine rearward of the t-case and it is a upside down arch shape to clear the driveshaft. I had 2.25 without the H-pipe and now have 2.5 with the pipe and I think the 2.5 with pipe "seems" to have a little more low end. A good single exhaust without restrictive reducers, coupled with a good performance muffler can be a great setup too. Alot depends on emission requirements where you are from and how deep your pockets are. Hope this helps.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
  11. tlarsw
    tlarsw 1/2 ton status
    Jan 12, 2001
    270
    Cameron, NC
    You will not see much difference between them, if any. I'd go with the cheaper of the two. I did a single 3" and dumped it down just prior to the rear axle. I had a dual 2.5" prior to that, that I bent up. Didn't really notice any differences in power. The big thing to be concerned with is the restriction of the muffler, the less the better!
    Also if you plan on using it offroad, you'll for sure beat it up, so use a setup that is protected as much as possible and works for your application. Also, if/when you end up replacing it, one tube is usually cheaper to replace.
    1986 K10 TPI350/NV4500/Gen2 Doubler/D60(ARB)/14FF(Detroit)/4.56 gears
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Unless you are planing on installing a crossover or H pipe on the dual exhaust. I think the single 3" will do better on torque at low RPM
    A single 3" mandrel bent system also only flows just a little bit less than a dual 2 1/4 pipe. It is not really not enough to make that big of a difference on a truck.
    After doing a little reaserch for my truck I decided to stick with the single 3", headers, and big block flowmaster. It builds torque real well at low RPM.
    If you are looking for more power at wide open throttle then dual exahust is proababally what you want
    <font color=blue>NEVADA: Where the pavement ends, and the West begins.</font color=blue><P ID="edit"><FONT class="small">Edited by Thunder on 10/29/01 02:00 PM.</FONT></P>
  13. BLUESMAN
    Oct 3, 2001
    951
    The K/5 is a 1978 model,with no cat. converter.I'm thinking it will make about 300HP with the cam,headers,intake and Q-Jet.I want to install a TH700 trans with a 241 T-case and 4.11:1 gears,35" tires.The K/5 is on a diet(no hardtop/tailgate and anything else I can pull!).I'm leaning towards the 3" single exuast with a Flowmaster muffler and tailpie.Thanks for all the input!
  14. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    I would go with a dual exaust cuz that stupid y pipe or any other made up single exaust at some time has to connect together and either the front d-shaft or something else will be in the way
  15. Brian 89KBlazer
    779
    Ontario, Canada
    Re: Single 3
    That was my main reason for going duals, Hammer. I'm building a new boxed chassis &amp; like I said earlier; switching to Flowtech Headers so why mess with the y-pipe when it's much cleaner/easier to run two pipes straight to the rear of the tires with a couple mufflers cut in line?
    I will try to find somewhere to run an H-pipe though; just not in the way for the front driveshaft
    Brian
    89KBlazer
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I meant to post this yesterday but it ended up in another thread....
    Get a set of headers and true dual 2 1/4" exhaust (bolt on Dynomax kit) and I'd bet that'd help immensely. Ditch the cat. Cheaper without it.
    As long as you don't have a visual inspection you can pass a sniffer test anyway. I helped my buddy's car pass over the weekend. No cats, no EGR, no smog pump, none of that nonsense, just an Edelbrock carb and intake and 1 5/8" headers and 2 1/4" duals with Flowmasters. It CAN be done.
    Bluesman,
    Your setup sounds great, but I suggest 4.56 gears. You'll be kicking yourself if you put 4.10s in it. I have that setup right now--and if I had the choice I'd have 4.56s. I am swapping my 700R4 out for an SM 465, so I'm glad I've got the 4.10s. But if I was keeping it, I'd go with 4.56 or 4.88 gears.
    And if I was in your shoes I'd save the money you'll spend on the 3" exhaust and buy the kit I did that I mentioned above.
    Tim
