Single front brakline conversion?
Discussion in 'The Garage' started by Sandman, Dec 20, 2002.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Since I have my front end completely torn out right now I was thinking it might be a good time to see if converting to a single front bake line was worth it. It would be like a Dodge front end or I think the ORD Blazer has done this? Has anybody tried this? Thanks.
  2. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    I like the idea, but I'm not sure what you mean. The wheels still have to turn left and right, so you need a flexible connector at each wheel right?
  3. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Yeah, and then a hard line that runs to the center of the axle, a juction of some sort and then a single line that goes up. I have had a few tires come off the rim and take out the flexible brakeline with it.
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    All you need is a rear brake line, and some hard line. The rear brake line has the junction on it.
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I don't know about yours, but my 79 Sub's rear line is short. Likely too short to work. I converted all three to braided using screw together fittings and -3 hose from Orme Bros. I ordered one extra of each fitting and two extra hose ends, plus enough extra hose to remake the longest hose. Those all go in the spares box.
