single key conversion
Discussion in 'The Garage' started by DwarF, Apr 6, 2004.
  1. DwarF
    DwarF 1/2 ton status
    Mar 29, 2001
    226
    Austin, Tx
    Is it a simple matter of getting the locks re-keyed to be able to have a single key for both ignition, doors (and tailgate) or is there something more to this?
  2. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    The keyways are different so you can't get the ignition to work in the glove/console/doors. There may be some aftermarket lock sets or ignition locks that would allow you to get everything keyed alike but it isn't possible with the stock stuff. /forums/images/graemlins/frown.gif
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    You just need to buy an older rig! /forums/images/graemlins/waytogo.gif My '71 Burb uses the same key for everything. /forums/images/graemlins/woot.gif /forums/images/graemlins/peace.gif
  4. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    I believe that LMC sells a matched set for the Blazers and alike...
  5. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    Most military trucks have same-keyed locks and ignition. Maybe you could get a set from one of the surplus dealers.
  6. DwarF
    Mar 29, 2001
    226
    Austin, Tx
    Nope. I called LMC after this post and found that they don't. I even argued that they must and made Tonya search though all her contacts there to se if it was so. She said they have single key setups for other models, but not the 82-88.
  7. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    i use one key for tailgate and doors. From my experience, all the gm cars i've owned have had a different key for doors and ignition. The round and the square one.
  8. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    My 86 GMC K3500 has a single key for the doors and ignition. The locks use the square key to lock and unlock the doors. It was done by the PO so I dont know how it was done.
  9. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    look in your phone book for a locksmith.
    they can normaly do it.
    i know G&T lock in Yuma AZ can do it.
    i just ditched the doors for tube doors...
    Grant /forums/images/graemlins/thumb.gif
  10. duece21
    duece21 1/2 ton status
    Jan 18, 2004
    501
    Aurora, CO
    Ditto, I pretty sure they can do it, prob pricy though. Check around.
    Good luck
  11. grd2go
    grd2go Registered Member
    Mar 28, 2004
    55
    Anchorage Ak
    I have found that 73 and some 74 chevy tks had the same ing and door key I used to save them I would have to look this weekend to see if I still have a matching set in the shed both of my plow tks use one key for doors and ing and it is the square key design one tk is a 74 and was like that when I got it my 76 plow tk got its ing and locks out of a 73 tk also check on the early seventys GM cars that had the ing in the colume some of them used only one key. /forums/images/graemlins/crewcab.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif
  12. rusty73
    rusty73 Newbie
    Nov 23, 2003
    3
    wasco,ca
    Chevy Duty sells matching ignition and door locks but not for the tailgate i don't think.
  13. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Yep, I bought matching door/ignition/glove box keys from chevy duty, or was it cheyenne? /forums/images/graemlins/thinking.gif Anyway, I think LMC sells an uncoded cylinder and blank key for the tailgate, then you can have a locksmith match it to the setup you buy from chevy duty, or was it cheyenne? /forums/images/graemlins/doah.gif
  14. DwarF
    Mar 29, 2001
    226
    Austin, Tx
    I have gone to a tailgate conversion and custom center console, so that doesn't really matter to me. All I really need are the doors and ignition to match. So I will give Chevy Duty a try
