Single or dual plane intake?
Discussion in '1982-Present GM Diesel' started by afroman006, May 25, 2005.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Awhile back I bought an intake from a hummer 6.2 on ebay and it turns out its a single plane manifold. Now, all civilian intakes I've seen have been dual plane. Since I now have one of each, which should I use? I figure since the 6.2 will have plenty of grunt for low end crawling, so I would like whichever manifold gives me a little better top end. This will be on a trail truck BTW.
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Go with the single-plane. Diesels don't respond to dual vs. single plane intakes as gassers do. Most of the dual-plane intakes were on C code engines with the EGR valve, and needed the extra spaces for the exhaust passages. The single-planes were used on the heavy duty J code engines. GM later did away with all dual-planes, I believe, and stuck with the single-planes. I have a single-plane intake on my engine right now.
    Casey
  3. afroman006
    Aug 21, 2002
    2,876
    Well the dual plane that came on the engine does not have EGR but it sounds like I'll be going with the single plane. Thanks.
