Single plain J-code 6.2L intake?
Discussion in '1982-Present GM Diesel' started by afroman006, Sep 13, 2004.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    All the J-code 6.2L intakes I've seen and sold off of CUCV's were all duel plain but I just bought a single plain intake off of e-bay. The seller said it came from a military hummer and is a j-code. Whats the deal? I know with gas engines single and dual plain intakes have different performance characteristics, I assume its the same with diesels? What kind of performance can I expect from this manifold? Thx
  2. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,040
    1,108
    Dallas
    There are three different single plane manifolds available.
    1) 1988-1992 6.2L single plane J - has a raised center section with a single CDR port on the passenger side. Stud orientation is 12 & 6.
    2) 1993-2000 6.5TD single plane F - has a raised center section with no CDR ports. Provision for 6 mounting bolts; no studs.
    3) 198?-199? 6.2L/6.5L NA single plane Hummer intake - has a flush center section with a single CDR port on the passenger side. Stud orientation is 3 & 9. ***This is what you probably have***
    All three are excellent, and you can expect better performance from your single plane than a dual plane. There's a big hole in the center with runners going out from it. I have one, and will probably work it into my future plans.
    Here's a pic of a Hummer intake:
    http://www.oliverdiesel.com/inventory/hummerintake.JPG
  3. afroman006
    Aug 21, 2002
    2,876
    Ok cool. Mine doesnt have a center divider, just a big open hole like yours. BTW, what is CDR?
  4. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Its a Valve, CDR stands for crankcase depression regulation valve.
  5. AgDieseler
    Jan 25, 2001
    1,040
    1,108
    Dallas
    It's the goldish "tuna can" located either just above the alternator on early 6.2L engines, or on the passenger side valve cover on later 6.2L and all 6.5L.
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Doh. This is certainly gonna make putting on an air intake fun!
