Single Plane intake
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazerman78, Oct 19, 2002.
  1. blazerman78
    blazerman78 Registered Member
    Oct 16, 2002
    77
    Connecticut
    hi everyone I was wondering if an aluminum single plane intake manifold would really kill my low end torque. A relative is giving me one for free tomorrow and i was wondering if it would be better than the stock one. I am currently rebuilding my motor so this would be a good time for an intake swap. Would this one be any better than the stock one? I have a 350 that is stock except for a set of headers. Thanks for the help!
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    Single plane intakes are more beneficial for higher RPM use, but some can be used. It depends on which intake you have, get the manufacturer and model and do some research before using it, some are made for a multi-purpose type RPM range which would be usable for you, and others are race only pieces which you will be sorry you put on your engine. A dual plane high rise type would be a better choice, maybe you can trade/sell it to a bracket racer and get the one your looking for.
  3. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Get the intake number.
    If you have the classic GM "equalized" dual plane intake then it won't hurt to put it on there. Drilling the hole between them was one of GM's dumbest things.
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    the only decent 1 plane i have ever used was a Torker II. decent low end, breathed reall good up high.
    I would get a Performer RPM with Air gap and a 1/2" or 1" wood spacer (a little testing might help find out whick is better for your application). the cooler temp will help make a bit more power, the spacer will give you a bit more top power, but still the benifits of a dual plane
  5. blazerman78
    Oct 16, 2002
    77
    Connecticut
    Ok I just got it today. It's a Holley Street Dominator, rated for 2500-8500rpm. Is this too high?
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yup too high.
    Sell it and get a better one. /forums/images/graemlins/grin.gif
