single ps belt to dual???
Discussion in 'The Garage' started by RootBreaker, Feb 28, 2005.
  1. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    Ok so I tightened my power steering belt... then after a few hours of wheelin it loosened up again.. I was told that the double belt setup is better... how can I get one? what cars, trucks would have it so I can goto the junkyard or aftermarket kit....
    thanks
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    an airconditioned truck will have a 2 groove pulley on the pump, 3 on the crank and 3 on the wanter pump. then you got the 2 belt power steering pump.
    you might want to check the brackets to make sure none are cracked, had the same problem and the bracket that bolts to the head and manifold was cracked.
  3. dyeager535
    26,980
    If it's loosening up, somethings not right. Belt should break before you ever have to worry about the pump working itself loose. In ther words, just figure out why it's loosening up and fix that, no need for a second belt.
    You'd need a complete pulley setup off of a donor vehicle to get them to line up likely, and power steering pulley is a pain to get off, need to get the puller to remove it. I had to deal with pulleys off of multiple vehicles putting my truck together...it's a major hassle. All sorts of different pulley combinations used, and that means that not all pulleys will line up with each other.
