Single Steering stabalizer or 2
Discussion in 'The Garage' started by BlitzK5, Oct 6, 2005.
  1. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    I have 38 X 15.50 that really meassure 37 X 14.50. Should I be using two stabilzers or is one good enough. And if its two what are the best ones to go with? I dont like the rancho setup because they are on top of each other which cause them to sit bellow the tie rod and im affraid it will just get all smashed up. What do you all think?
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I have 2.. mailny because i got a dana 60 front with them.... free of course... :haha:
    buy stabalizers and get d60 free ...
  3. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I think if your frontend is aligned and the joints are in good shape you shouldn't need more then one. I run a single which is about 100 years old with 37X13X15 boggers and I don't have any problems.
  4. BlitzK5
    Jul 29, 2005
    288
    ok thanks.
  5. 72 SAC
    72 SAC Registered Member
    May 7, 2003
    76
    sacramento, ca
    I think that 2 is really just for show. I thought that I need 2 at one time but after I put it on, I didn't notice much of a difference.
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Ill give ya 50 bucks for the used stab's so long as I get the 60 thrown in to make it worth my while.
  7. mtnman
    mtnman Scrap metal fabricator Premium Member
    Sep 8, 2005
    2,087
    30
    On the farm , Missouri
    If you need 2 you are just covering up the problem. I havent even run one in years. :D
  8. BlitzK5
    Jul 29, 2005
    288
    Yeah all my ball joints are new so I'm assuming 1 should be able to handle the 37" TSL's.
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Agree. If you feel you need 2 stabilizers, you need to find out why it is unstable to begin with. Don't just do it, It may hide a small problem from you untill it turns into a big, serious, costly, could-kill-somebody-on-the-road kind of problem.
