Siping BFG Muds
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FWP, Oct 16, 2000.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Anybody ever done it themselves? How hard was it? Reduced tire life? Torn off pieces when wheelin? Just thinkin about it for Winter, just the two rows of center studs.
    <font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
  2. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    DISCOUNT TIRE does it for 10 bucks each. done it to mine and the difference was huge
  3. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    <font color=red>DONT DO IT</font color=red>
    i had this done to my last BFGs and i still got stuck when wheeling and hit a sheet of ice and i had mine chunck up when the tires spun on a rock and they tend to pick up sand and pebbles and throw them more i would never do it again
    <font color=green>SMP</font color=green>[​IMG]
  4. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I've heard good things about siping. I think 4WOR or Four Wheeler did an article about this not too long ago.
  5. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I cut about half of my right front before a wheeling trip just to see how it would hold up. I used a utility knife with the blade out about a 1/4" and put two cuts in each lug. All my other tires got cut up pretty bad on a hill climb that was mostly slate and field stones (had to use the skinny pedal quite a bit). I figured the siped lugs were going to get shredded but they were the only ones that didn't get cut by the rocks. I'm going to finish cutting the rest of them this week.
    Joe
    RIT Mini-Baja http://www.rit.edu/~bajawww
    Team Mudnuts http://www.mudnuts.org
  6. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    Mine are siped, I have literally crawled straight up a rock face that everyone else who was following me spun their tires on, I never spun a tire. the siping will also keep the tire cooler thus increasing tread life.
    Dan
    <font color=red>get involved with land issues or lose the land</font color=red>
  7. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Jason, yeah, I read it, that's what made me think about it. thanks
  8. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Mudfanatic, When you say yours were done, how? and by whom?
  9. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    Are you all just Siping the inside lugs? I was also wanting to do this to my BFG M/T's. How deep are the cuts suppose to be?
    http://k5junkie.coloradok5.com/
  10. mudfanatic
    Feb 18, 2000
    614
    Aloha, Oregon
    Americas tire company did them when I bought them, they are the BFG Mud Terrains and only the center lugs are cut, I am not sure how deep though.
    DAn
  11. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
  12. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Makes sense. I think I'll try it on 2 tires first, see how it goes. Better call and see how or if it affects the warranty though.
  13. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
  14. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    You know, those little bitty grooves that are cut sideways on a tread, for the water to get through, or to bite the snow. As opposed to going out and buying ATs
  15. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    WHAT ARE YOU GUYS TALKING ABOUT?????? What is 'siping' a tire?
    blazen91
  16. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Hand siped a set of TSL swamps a couple years ago. They became famous in 4WOR. I used a hot siping iron like the circle track guys use. Cuts were about 1/4" deep and every 1/4" across the center tread. They added noticibly to the traction. Icy/snowy situations weren't as scary as they could be and it helped out a lot on we slickrock. I did have "chuncking problems" and my solution would be to leave at least 1/2" of uncut rubber at the front and back edge of each tread lug, then cut every 1/4" across the center. This would keep the lug edges from being cut off. I would do it again as long as I could do it by hand. For a lot of offroad use, I would stay away from the machine jobs, they put the cuts where ever they fall and it could be too close to the edge of a lug. For mostly street use, a machine job would be fine.
    good luck
    SW
  17. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    Siping tires is easy to do yourself and a very effective traction aiding procedure. The idea is to make cuts in the tread lugs perpendicular to the tire rotation. No material is removed from the tire, it is just cut. You just use a plain utility knife, no special "heated blade" is needed. You hold the blade out straight away from the tire and cut through the lug from one side to the other. The cuts can be spaced from 1/4" to 1" apart, depending on the tire and where you will be driving. Don't put any sipes real close to the leading or trailing edge of the lug, or it might break off. Don't cut any deeper than 1/8" to 1/4" and make sure that you don't get within 1/4 of the tire carcass. A deeper sipe allows more tread flexibility, but gives more chance for chunking. If you wear throught he sipes, just cut 'em again. After you have siped a lug, you can rub your finger across it and it will flex, revealing all of the new biting edges that you have added. Just sipe one lug at a time, and go all the way around the tire. You don't want to sipe the outside lugs (left or right of each tire), because this is what accelerates the "chunking". Your wet traction is all gonna come from the center lugs anyway.
    In my opinion, it's actually better to do it yourself, because you can place the sipes where they logically should go, whereas a machine just spaces cuts evenly all around the tire.
    Hope that clears it all up...
    '85 JIMMY
    '90 paint/grill/trim 5"susp 33/12.5/16.5
    Fresh 350 B&M '87 TH700
  18. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    Hey everybody. Here is a site Depdog posted a few months ago. And there are a few threads about it in the forum if you do a search on 'sip' (for sipe or siping) and 'tire' you can find them.
    http://reality.sgi.com/rogerb/4x4/CheapTricks/tiresiping.html
    <font color=blue>I don't get stuck, I'm just in the mud when I stop for lunch [​IMG]
    - NJFourWheelers</font color=blue>
  19. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Excellent link. Thank you all for the input.
