Sitting level ????
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 71blaz, May 10, 2003.
  1. 71blaz
    71blaz Registered Member
    Aug 1, 2002
    86
    southwest colorado
    My 71 does not sit level the drivers side is ~1" higher than the pass. side. I put a new lift on from ord springs front and rear, during the installation I took measurements to verify what the lift was going to do and it rasied everything the same amount. so the 1" lean was there before the lift.I thought it was the spings,but I quess not. /forums/images/graemlins/frown.gif I have looked at all the body mounts and they are all the same ( 1" body lift) So any ideas what could be causing this problem ?????
  2. 72beater
    72beater 1/2 ton status
    Oct 11, 2002
    224
    Nation\'s Capital
    is it higher front and back, or just one of those?
  3. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    thats so it will sit level when you get in it. cause there is always load on the driver side and not as often load on the pass side.
    thats it yes...... /forums/images/graemlins/wink.gif
  4. 71blaz
    Aug 1, 2002
    86
    southwest colorado
    yes, it is higher front and back.
  5. Nikk
    Nikk Registered Member
    Dec 16, 2002
    34
    Lacrosse, WI
    Is it all too one side (front and rear) or does it look like only the front, and the rears ok. I ask because my truck too leaned to the side (drivers), at first I thought it was only the drivers front and then when I took it to the frame shop it was pointed out to me that it had also been a little low in the rear on the pass side (couldnt really tell till the guy showed me). This ended up being a twist in the frame, tuns out I also had a little side sway(which is some what of a bow from side to side. Anyway, best thing is to take it in and get it looked at. Dont be surprised when you get the estimate most places that I found charge 65 to 75 bucks an hour. It cost a chunk of change but hey my ride sits pretty darn level now, I can finnaly drive it without thinking everyone is looking at me because I'm leaning /forums/images/graemlins/thumb.gif
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Whats the big deal?? As long as it doesnt sit A1 HAHA /forums/images/graemlins/rotfl.gif
  7. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    you can add another battery tray on the drivers side. The added weight over then next 10 years may level it out a bit /forums/images/graemlins/thumb.gif After thinking it over you might not be as tweeked as you think. Your tires I am sure are not identical, body mount differences, and alot of accesories might not be spreading the weight equal accross the frame causing it to lean more to one side. Do you have any weird handling problems or tire wear? I would expect most trucks this age to have there frames outta wack by now. Most are not even close to exact when they leave the factory due to mass production flaws. I know when I just had the body off my truck and was shortening the frame, the x measurments about scared me! I ended up drilling most of the crossmember rivets out because they were lose and replaced them with bolts, and this brought it back closer to specs. I need to shut up now...
  8. 71blaz
    Aug 1, 2002
    86
    southwest colorado
    I like the idea of the extra battery, So you can send me that factory drivers side battery tray you aren't using /forums/images/graemlins/thumb.gif. I also found when replacing the spings that the pass. side rear sping had 3 of the 4 leafs broken in half /forums/images/graemlins/confused.gif think this could have something to do with my problem
