Six lug Dana 44 vs eight lug Dana 44
Discussion in 'The Garage' started by odoa3, Apr 30, 2004.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I currently have a six lug Dana 44 in my '75 K5. Have a eight lug dana 44 from a 3/4 ton 80's Suburban that I can have for free. What is the difference between the two? Is the eight lug stronger or just have different lugs on it? Worth switching it over? Thanks for the info.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Same axle. Outers are the only difference.
    SOME 3/4 tons have slightly larger calipers although they're interchangable anyway.
    3/4 ton rotors are slightly larger in diameter.
    You will have to grind the brakes on an 8 lug axle to clear 15" wheels.
    Neither is stronger than the other.
  3. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Some also had thicker axle tubes......
  4. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    You are the man for the Dana questions! /forums/images/graemlins/waytogo.gif So, I can just switch over the outers, and be good to go with the front end I have, correct? Thanks!
  5. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    You can convert either to 8/6 lug.....
  6. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Great! Exactly what I wanted to hear! /forums/images/graemlins/woot.gif
  7. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Anytime /forums/images/graemlins/waytogo.gif
  8. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    All 1/2 and 3/4 ton calipers are the same.
    You do not need to grind calipers or brakes on a D44 or 10 bolt to fit 15" rims.
  9. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I think there are a few guys that have had to do a little grinding to fit 15's. It seems I noticed the rotors on my 3/4 10B were a little larger than my old 1/2 10B. /forums/images/graemlins/thinking.gif
    Also the backspacing would make a big difference I think. /forums/images/graemlins/thinking.gif /forums/images/graemlins/doah.gif
  10. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    FYI-
    If that 8 lug axle is from an 80's 'burb, it's not a D44, it's a 10b. The last of the D44's were around '77-78. /forums/images/graemlins/pimp1.gif
  11. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    99% of the time you are correct Mr. Scott. Hehe, not this time though. I did quite a bit of grinding on Shewheelers 3/4 ton calipers to fit her 15" rims. /forums/images/graemlins/pimp1.gif
  12. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    One thing you guys need to keep in mind is that not ALL Dana 44's are created equal. The older ones, like OEM on my burb, had smaller diameter axle tubes and smaller u-joints. There is also a difference in diameter of the axle shafts, although the neck-down portion of the shafts is close to the same diameter. The spindles and bearings are also larger on my '77 axle.
    So for me, going to a '77 8-lug D44 from a '71 6-lug D44 WAS an upgrade. /forums/images/graemlins/waytogo.gif
    Here is an old thread on the subject.
    But in this case, since his original D44 is a '75 model, the only real upgrade would be to switch the outers, which will give him the larger brakes, spindles and bearings. /forums/images/graemlins/waytogo.gif
  13. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I hear that the guys with 2.75" BS don't have to do much grinding, if at all. But those of us with 4.25" BS have a fair amount to do. /forums/images/graemlins/waytogo.gif
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  14. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    But everyone knows Dana built the 10b !
    according to Grim /forums/images/graemlins/1zhelp.gif
    FYI-
  15. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    IIRC, Cheryle's wheels are 2.5" BS. I didn't have to grind much, mostly just the casting mark and a bit more, but I did have to grind some.
  16. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I've got 2.75" BS on my 15's and I didn't have to grind at all /forums/images/graemlins/thumb.gif
