Size for Dana 60?
Discussion in 'The Garage' started by 53chevy, Feb 11, 2007.
  1. 53chevy
    53chevy 1/2 ton status Premium Member
    Dec 29, 2004
    369
    7
    pitcairn
    What size socket do i need to take the ubolt off my dana 60. The truck is up at my garage and thats about an hour away, i think its over an inch. Also what other tools should i take up to put my zero rates on. Thanks
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    my ubolt nuts as well as the stud nuts are all 15/16".
    for the zero rates i'd bring a couple sockets for tightening the center pin and offset pin if you decide to do that. a pair of vicegrips for holding the pin in place while you tighten. something to cut the center pin down. big c-clamp for holding the leaves together while you drop the stock center pin out.
    jack/jackstands for supporting the axle and truck independently. if you are offsetting the axle, you'll need to make sure that your ubolt plate is drilled or slotted to accomodate the new center pin location.
    all i can think of at the moment.
  3. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    15/16 socket for the u-bolts
