size of 203 rear output shaft yoke nut ?
Discussion in 'The Garage' started by R72K5, Dec 23, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    anyone know ? nut that holds output shjaft yoke on back of 203 case '70's ?
    like 1 1/4" ?
    thanks
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i think its 1 3/16 i have no idea why that sticks out in my mind but it does.
    If i was home, i'd check for you /forums/images/graemlins/frown.gif
  3. potato76
    potato76 1/2 ton status
    Mar 21, 2002
    922
    phoenix, AZ
    I just happen to need the same question answered.I am having the same problem, i need to find a socket big enough to get mine off as well
    /forums/images/graemlins/thumb.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    oh and what is the front third of the 203 case called, the front 1/3 that bolts to end of tranny and that is front of the chain case part of the case? is itt the range box ?
    thanks
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Yes, that portion is the range box. I believe the nut size is 1 3/16" like zakk said.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok, cool, thanks /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
  8. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    thats what i got my $ on is 1 5/16
    but it may even be a 1 1/8 ""
    also ya need the 1/2 " drive as the 3/4 drive scockets walls are to thick to fit in the yoke hole
    the large kit from 1 inch up to 1 1/2 " by 16ths is a great investment if ya can swing it
    as they are all commonly needed sizes for ball joints and 208 & 241 t case drain and fill plugs and yoke nuts for axles and t cases
    R
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep is 1 5/16" for sure, i just got case complete disassembled, yokes werent bad to get off at all i used a huge pipe wrench to hold yokes and went for it, the front yoke nut is 1 and an 1/8"
    with large flat round(square on trans case, round on CV shaft flange) 4 bolt style yoke
