Size of nut on 2wd sector shaft ? to remove pitman arm.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ColAdo82K5, Jan 5, 2004.
  1. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Hey,
    I'm going to pick up either a 2wd sector shaft or a 2wd box soon. I have a puller, but don't know what size that massive nut is that holds the 2wd pitman on. Or is it more of a "use the cresent wrench" type deal ?
    Thanks for any ideas...
    Blake
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    should be 1 5/16"
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you will need more than just crescent wrench, it will take some pipe and a breaker bar, i use 3/4" drive, they are VERY tight.
    good luck
  4. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    pipe wrench worked for me.
  5. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    I've got a 3/4" drive set Blake, since you've got my ball joint adjuster anyway /forums/images/graemlins/grin.gif
    Or we could just put it on my truck as soon as my parts get here /forums/images/graemlins/grin.gif
  6. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Hey,
    Blake
    I think you should use that Hammer we found, a junkyard screwdriver and a jack handle. That should do the trick. /forums/images/graemlins/thumb.gif ***
    When are you going "junkin'"?
    Also to hijack your thread - Chris you are back in town? We all need to go junkyardin'
    *** Edit - tbis is what we used at Melloways to remove a 32 Spline Output out of a Frawd NP205! Worked nicely.
  7. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    YARDIN' BABY!!
    Blake,
    I just use a 15" crescent wrench on the sector nut.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Step 1, take box home
    Step two:
