skid plate for gas tank
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by sganje, Feb 12, 2007.
  1. sganje
    sganje Registered Member
    Jul 31, 2005
    44
    Denver, CO
    I did a search and didn't find anything so I will try a post. I am wondering if anybody has a skid plate or made one for the gas tank on the 1st gen. I have a poly tank and don't want to have a rock go through it. Any ideas? Any pics? Thanks
  2. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    There was a guy who made some reproductions a while back, but I think he sold through them quickly. They wouldn't be very difficult to make. The factory skid plates are made out of sheet stock with a few bends a few welds.
  3. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Mine has one that I'm sure is not factory. 1/8 steelw/angle iron ribs. Has about 1 inch clear ance to the bottom of the tank. It has taken some pretty hard shots, and not bent. Will try to get some pics in the next few days.
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I did have a factory skid but I gave it away.
    I made a skid with some square tubing, 1x2 I think, I made a letter H then welded up a peice of sheet steal to it. Then I made 4 legs that bolt to the frame. Here is a side view of it:
    For your poly tank I would try and find someone with a factory skid. It will fit perfect!
    Good Luck
  5. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,951
    247
    Released from Pueblo, told I belong in Southpark
    here is a factory one
  6. 70jimmy
    Mar 3, 2000
    5,951
    247
    I got mine from azblazer, but junkyards might have one, or if needed I might be able to find another here.
  7. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,235
    284
    San Jose, California
    Ah, good to have pics. The factory one looks easy enough to fab up and have it look pretty close. I don't have much confidence I'd find anything that old in a wrecking yard around here.
  8. Burt4x4
    6,854
    Pacific Fab is in Morgan Hill..they could easily make you one :D
  9. bp71k5
    Mar 31, 2006
    6,235
    284
    Oh yea!
  10. sganje
    Jul 31, 2005
    44
    Denver, CO
    Thanks for the pics guys. I am willing to try and make one I just needed a push start. Now that I have a good idea I think I can fab something up. Thanks
  11. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    The 90 blazer I recently parted out had one.
    Seems like they'd be around still.
    Looked to be easy enough to modify to work with our years, just in case you didn't find an original one.
    It's my plan to cut this one down to fit around the new fuel cell.
  12. bigdon-70blazer
    bigdon-70blazer Registered Member
    Apr 29, 2006
    38
    Poplar Bluff, MO.
    Here is another pic
    Here is pic from mine of the blazer!
  13. bouncytruck
    Oct 11, 2001
    858
    Bothell, WA
    My factory skid plate is sitting in my garage. I might be able to take some more photos for ya if you need it.
  14. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    In December I pulled the gas tank skid plate from the back of the barn where it has been sitting when I pulled the tank to have it cleaned and sealed. I cleaned it up for paint about 2 years ago and, well, just never got it painted.
    Used the 3M undercoating/rubberized stuff and the finished product looks great. To bad I moved it before it was dry, ended up putting the smudge you see in the side shot. May sand it a bit and touch it up, maybe not.
  15. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    You are worried about a smudge in the undercoating on a skid plate??? :p:
    j/k looks good
  16. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    whoops, forgot to add the :haha: icon after that sentence. Though I do think I will touch up my inner fender black paint I sprayed on recently - dang cat just had to walk on the fender before it was dry :mad:
  17. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    what guage steel is that factory skid? any internal bracing? Thanks
  18. 70jimmy
    Mar 3, 2000
    5,951
    247
    No Internal bracing at all, what you see is what you get. I will have to see if I can measure the thickness.
