Skid plates.. Tcase, dif, etc
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Sep 12, 2001.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Where can i get skid plates for my 208 , and 10bolts... or do they even mkae skid plates for those...? And are they easily installed? Thanks
    6in 87' K5 w/ 35" BFG muds.
    Kn filter
    What I need: 4.11 gears, Lim Slip Dif, Force2 Catback, 2"springs 4"flips,SSR's
  2. MUDNUTT
    MUDNUTT 1/2 ton status
    Aug 1, 2001
    339
    Mn
    <font color=blue>why not make your own. done right they would be stronger than stock
    <font color=blue>DRIVE IT LIKE YOU STOLE IT [​IMG]
    <font color=red>PROUD TO BE AMERICAN [​IMG]
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I agree,build them your self.Its alot cheaper and you get pretty much exactly what you want.Iv got pics of mine on my webshots page in my sig.
    A balanced diet is a beer in both hands.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  4. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    how do you build one ? =P
    Kn filter
  5. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Fire,metal,and a little imagination.
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You forgot the two most important tools - Beer (or other choice of beverage) and an assistant to go pick up whatever piece you tossed in the street after realizing you cut/measured it wrong and it didn't fit (not that I would ever do such a thing)[​IMG]
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  7. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    Why build skid plates to begin with. The housings will take a lot of abuse. Just grind the rough stuff off so it will slip off the rocks instead of hanging up. I build differential covers with built in protection from the rocks. Check out my site.
    <font color=green>Steve Frisbie</font color=green>
    <a target="_blank" href=http://www.mooffroadoutfitters.rockcrawler.com>www.mooffroadoutfitters.rockcrawler.com</a>
  8. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I built the gaurd for my t case because I didnt think my 208 would support the weight of my truck and it lets me slide over stuff rather than get caught on the housing.The front dif gaurd keeps my dif cover safe and gets rid of that flat spot at the bottom of the cover so I can slide over rocks .I wish I would have built something for my fuel tank before I crushed it and tore a hole in it .I consider the gaurds a wear item that can be easily and cheaply replaced.
  9. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Do a search for axle trusses with skid plates if you want some... if you find the Pro Comp ones, they suck. They are deisgned for looks not wear. You can get a skid for the t-case at a Chevy dealer. They don't run much either. There are several folks on this site that do metal fab work. If you are in need of something post in the parts wanted section what you want/need and I am sure someone can help you out. [​IMG]
    9/11/01... "We will overcome"
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>www.chevycagal.homestead.com/steph.html</a>
