Skyjacker 4" review!!!!
Discussion in '1936-Present Suburban' started by 89GMCSuburban, Nov 21, 2002.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Skyjacker 4\" review!!!!
    OK, where do I start...oh...installation. 3 days it took, mainly because of the wrong parts in the kit from Skyjacker. It came with two different size bushing eyes when I needed the same size...after some searching, got the right parts and put the front in.
    In the end, the front is now 5 1/4" higher than it was before. It hasn't settled much yet, but that'll change. Ride is a controlled feel, not rough, not wavy, perfect. I really do like this kit, but I'd say get some RS9000's to dial in the ride. Flex, I haven't flexed it hardcore, but I twisted the axles up and it does pretty well.
    In the end, my front exhaust needs to be cut for clearance, my front shaft needs a spacer or to be lengthened, my sway-bar needs to be lowered, and the rear needs traction bars 'cause of BAD axle wrap.
    In the end, I'd say this is a great kit. Cruise down bumpy dirt roads at 60 with confidence. Anyways, I'll have some pics when I can get them!
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Re: Skyjacker 4\" review!!!!
    How is the rear lifted? Blocks?
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif
  3. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    4" blocks, add-a-leaf. One big thing I thought about is I left the spring clamps open for flex, that's probably doing it.
  4. BurbinOR
    5,829
    Oregon
    The blocks are most likely what is causing your problem. Been there, fought it until I put in 4" rear springs. Worth the money when you can afford it. /forums/images/graemlins/burb.gif
  5. BurbinOR
    5,829
    Oregon
    By the way, do you have the Fosgate subs in a box? I'm wondering how the Burb guys do their systems........since my K5 is sold and moving up to Burbville. /forums/images/graemlins/burb.gif
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Before I have my system stolen outta mine, I built a custom sub box for 2 15"ers. Built the box to specs, but it was built so that the subs were firing towards the floor at a slight angle to the front of burb about 1" off the floor. That is about the best sound that I found. Just my .02cents.
  7. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    I have them in a sealed box I bought from www.millionbuy.com. Good box, had to seal it a little more around the junctions, but overall, it's great. Was only $59.95. I stuck it behind the third seat and have it facing towards the front. No problems and I have PLENTY of room left. A plus is that the third seat now vibrates from the subs...
  8. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    im about to buy a 4" all spring skyjacker with shocks from a fellow ck5er...sounds good so far...rancho rs9000 is on my list..but those things arent cheap..take some saving up...for me at least /forums/images/graemlins/crazy.gif
  9. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    id lik to know how to set it up in a k5...ive been thinking about it..but i dont want any side panals..its going to pretty bare in there..rhino lined floor with rubber floor mats..and rhino lined sides...
  10. BurbinOR
    5,829
    Oregon
    I did it in the side panels with my K5, but that is sold............here's how I did it then. Not the ultimate for thump but I was after room, not thump. Those are 10" MTX Thunder 5000's in there. Don't want to go that route, so a box of some sort will probably be the answer. /forums/images/graemlins/burb.gif
  11. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    I've just been looking at replacing the factory 10x4s with 10s. there is planty of room and the echo form the sheet metal should increase the bass sensation. That way I dont' have to take up any space. There is enough air space behind there. The best part is they wouldn't be visable from the outside with factory tint.
  12. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    yeah i'm gonna put a set of 6x9s where my 4x10s are now and then some 10"s in the side panels in the very back most likely. probably just end up eliminating the spare tire hole.
  13. FLASHLIGHT76
    Jun 20, 2002
    255
    OREGON
    Thats where my tools and stuff are going. Any one know of there is a panel out there to replace the left side rear so it looks like the right once the tire has been removed? I've never seen it as an option to not have the spare so I would assume they don't.
  14. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i MAY make some wood carpet coverd panals...i just dont like the look of a big open box sitting there..it just wounldnt look right..and i would rather have the room..i could always take the side panals and speakers out when i went mudding anyway..
    bryan
