Skyjacker 8" 56" Q's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RedDwarf, Oct 21, 2001.
  1. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Skyjacker 8\" 56\" Q\'s
    Well, the Dwarf is cooking something.
    What I need is for someone that has the 56" long Skyjacker 8" packs to take some measurements. I need the location of the center pin from either end and an actual eye-to-eye measurement as well as an estimate of the shackle angle.
    Apologies for the third degree, but if you can help me out, that would be great.
    <P ID="edit"><FONT class="small">Edited by RedDwarf on 10/21/01 06:09 PM.</FONT></P>
  2. Dip Stick
    Dip Stick Registered Member
    Oct 14, 2001
    73
    Murdock, Florida
    Re: Skyjacker 8\" 56\" Q\'s
    A true eye-to-eye is like 55.something on my buddies truck
    <font color=red> It's not what you drive, it's how you drive it</font color=red>
    1986 K20 & Lots of Rust
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Sorry to disappoint you, but Skyjacker only makes the 56" rear springs up to 6", not 8". [​IMG]
    I called SJ asking if they could make some custom made 8" rear springs for my 56" long K30 rears and their first comment was: "call National Spring and have them make some for you." [​IMG] Sorry, but no thanks!
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  4. RedDwarf
    May 9, 2001
    816
    SUCK! That is NOT what I wanted to hear. [​IMG]
    Thanks for your help Wes.
    Still Poundin' "pavment" after all these years!!! [​IMG]
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, I understand how you feel. [​IMG]
    I was trying to get some of those springs for my K30 once. Nope. SJ sells the 6" springs and a block kit to raise the lift up to the 8". Not quite what I wanted.
    Another thing you could do is just get the 52" springs. But then again, you were probably looking for longer springs, right?
  6. RedDwarf
    May 9, 2001
    816
    Yes, for the expressed reason that the pins are not centered on the 56"ers.
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Well, you could use the SJ 6", 56" long springs and a 2" ORD shackle flip to make the 8". Just a thought. [​IMG]
  8. RedDwarf
    May 9, 2001
    816
    Nope, can't flip the shackles.
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    I guess your only choice now is to use the springs and 2" blocks. [​IMG]
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Back to your original post, of taking a measurement on the 56" rear springs.
    I have 56" rear springs from SJ that are 4" lift on my '85 K30. Would these springs work for whatever measurement you needed?
  11. RedDwarf
    May 9, 2001
    816
    Well, I was wondering if they changed the wheelbase at all(location of pin). I have heard of other companies trying to keep you from having to lengthen your driveshaft by moving the pins.
    And the blocks are out too...
