Skyjacker 8 in Softrides
Discussion in 'The Garage' started by FL84K5, Feb 22, 2003.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Im looking for info on this system, front and rear springs. How do they ride? Anyone have them? This is primarily a mud truck and a daily driver. I would be running 39s
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    you will have to trim for 39s.
  3. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I'm curious to if anybody has input. I am considering this for mine. Got 44's to stuff under with 2 inches of body lift and using zero rates to slide the front axle forward a bit. I heard the spring rate was pretty good and looks pretty decent in the tech section here. I also hear that the spring rate isn't even from one spring to the next, hence the truck never sits level with a skyjacker system. I hope someone can tell me that isn't true...
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Those spring rates in the tech section are for 4" lift as well, I think that the 8"ers are most likely a different rate. Its possible they aren't but I doubt it.
  5. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    My friend has the 6" Skyjacker Softrides in his 72 Blazer... there is nothing soft about them.
  6. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    I've got the 8" Softrides and I couldn't agree more. Why can't they just be honest and call em Skyjacker Stiffies?
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    now now its HD not or Super Duty, not stiffies.
  8. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    go with the superlift 8" HD springs...they ride real well on the street and can flex out a little bit if they need to...ask boss how they ride if you want a second opinion he rode in my truck when we were up in penn. for the UCP run...
    oh and by the way depending on what 39s you run you might not have to trim...i ran 39 boggers on mine with 8, and didnt have to trim until i started running some trails...BOWTIE went the same route
    Later
  9. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    I guess I shouldn't expect any 8 in springs to ride decent. Maybe I'll go with 6 inch suspension and 3 inch body to fit 39s. The fenders are already cut
  10. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    NO dont do bodylift...oh for the love of god dont do bodylift...
    go with the 8" superlifts and 39s...
    Later
  11. Ryan B.
    Jul 18, 2001
    5,693
    CA
  12. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah no body lift, except for the 1".
  13. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    What is so bad about a BL? I have had them on both my rigs and never had any problems w/ them. I just dont get why everyone hates them. /forums/images/graemlins/confused.gif
    IMO, a 6in lift will ride and flex better than an 8in. But Jason (FL84) already knows my opinion.
  14. dkodyssey
    dkodyssey Registered Member
    Feb 22, 2003
    40
    otisville,ny
    i was looking at the 8" but im gonna go 6".will 37x13 boggers fit or will i need a body lift?
  15. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    they'll fit fine if your not afraid to cut the fenders, I am probably going 6" with 37 SSRs.
  16. dkodyssey
    Feb 22, 2003
    40
    otisville,ny
    i went to skyjackers site and outta the two 6" kits wich is better,front leafs and rear blocks,or front and rear leafs?im thinking the front and rear leafs,but i dont know.will i need any shock modifacations besides 6" longer?i know if i went with the 8" i would need a longer driveshaft,will i with the 6"?
  17. dkodyssey
    Feb 22, 2003
    40
    otisville,ny
    someone?anyone?
  18. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Yes, what is wrong with a body lift? (Just wondering cause I really have no idea) /forums/images/graemlins/crazy.gif
  19. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    More leverage on the bolts and mounts. The taller they are the worse it gets. If you use the bed for hauling it puts a lot of stress on the steel over the pucks. The pucks on most 2" & 3" are plastic. Plus the usual stuff w/ lines, wires, linkages, and the fan.
  20. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    IMO get a 6in kit w/ front springs and rear blocks, just dont use the blocks and do a shackle flip in the rear to get 4 inches then use a 2in block. OR use an Echobit bolt on flip (5.5 inches) and a Zero Rate in the rear. Or use the blocks to get it done kwik. Or get all spring. LMAO!
    Theres lots of options. /forums/images/graemlins/crazy.gif
