Slaughterhouse Gulch PICS ***Some carnage too***
Discussion in 'Rocky Mountain Region' started by mrk5, Nov 6, 2004.
  1. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    Left to Right: MrK5(Scott), B_to_C(Nick), Shawn, and ugly(Alex)
    Uhh, which way do we go? /forums/images/graemlins/rotfl.gif
    Playing in the mud pit.
    On a side note, you'll notice B_to_C's truck in the background at the mud pit. It's not because I'm trying to make Nick look bad; he suffered some damage. I'm sure he'll post and explain.
  2. ktedesco
    ktedesco 1/2 ton status
    Mar 21, 2004
    365
    Colorado Springs, CO
    Re: Slaughterhouse Gulch PICS
    Looks like I missed out on alot of fun. That mud pit is always fun. We moved all day /forums/images/graemlins/frown.gif, wish I could have been there. Did Bo and John make the trip?
    Nick, what happened to your truck?
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Looks like it was fun time . I like the snow /forums/images/graemlins/thumb.gif
  4. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    John and Bo didn't make it. I know John decided that it would be good weather to get some things fixed on his truck.
    Paul, I love the snow too! /forums/images/graemlins/peace.gif
  5. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Yup, there was a little bit of carnage today. About half-way through the trail I hear this nassty gridning noise comin from the transfer case / front end area when under hard acclereation. I looked around but couldn't find anything... A little bit further down the trail I looked again and noticed the bracket that connects the transfer case to the cross member is sheared /forums/images/graemlins/eek.gif . this was letting the transfer case/ transmission flex under heavy load and the front driveshaft was actually rubbing up against the crossmember /forums/images/graemlins/doah.gif(the grinding noise i was hearing). But pictures are worth 1000 words so....
    Front:
    Back:
    And while I was poking around down there I came across this... /forums/images/graemlins/yikes.gif /forums/images/graemlins/shame.gif
    Not to mention my transfer case is pissing a little more steadily than usual....
  6. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    I'm glad you made it back okay.
    Am I seeing that correctly, the frame is cracked? Dayum!
  7. B_to_C
    Jan 15, 2003
    1,861
    yup, definitely cracked /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/frown.gif
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    My frame did the exact same thing in the exact same place. I didn't find out about it till the transfer case crossmember broke all the way threw the frame and the crossmember fell.
    A local fab shop welded on a piece of angle iron about 3/8" thick in to fix the damage. Since then I have had no problems with it. I will tell you though if you start laying the crossmember and tcase down on things hard it will start to bend the framerail lips up. I am having this problem on the non-patched side.
    You need to get that frame crack taken care of immediately.
    Harley
  9. Storm Trooper
    Nov 24, 2000
    4,640
    Glad you guys had a good time. I would have liked to make it but work won't let me. Maybe next time /forums/images/graemlins/dunno.gif
  10. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    If you need that welded up I can talk to my father-in-law and he could probably do it.
    I'm thinking you should post up in the Garage and see what everyone else thinks about welding it up. I wonder if it would be better to weld a piece of strap over it or box up the frame in that area. Seems like it would be the same concept as the frame repair kit for the steering box. Looks like the exhaust might be in the way though.
  11. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Don't box it.
    Stop drill the crack and weld it closed. Then grind it flat. Take a piece of 4"x4" 1/4" (or 3/8") thick angle iron and weld it over the area. Make the peice of angle about 2" bigger then the crossmember and leave about 1" on each side. And then weld it to the frame to make a new foot for the crossmember. You will have to drill the new plate with the bolts for the xmember.
    That should make it plenty stout.
    Harley
  12. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    I just now noticed you had posted that.
    I came back and saw that you and Trooper had posted before me. You must have posted while I was typing. I type too slow.
  13. ugly
    ugly 1/2 ton status
    Aug 8, 2004
    157
    Denver
    Good fun! But, I wasn't able to get my tcase into lo all day, and the qjet bogged a dozen times.
    I am kind of a puss. When we were going down from the top it was covered in snow and I had a very high pucker factor as the blazer slid down in many places (bolgna skins don't grip very well).
    Sliding! SLIDING! NO TRACTION! SH-T! Bail into that tree, yells my passenger.- newbies /forums/images/graemlins/doah.gif
    I have some good video, where can I post the files, and how many megs are available.
    Nice carnage Nick,
    yo,yo,yo...out
  14. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    There's always reverse to help slow ya down /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  15. B_to_C
    Jan 15, 2003
    1,861
    That would be awesome Scott, let me know... And I posted in the garage to get some more exposure (assuming it doesn't get burried).
    P.S. I like how you changed the title of the post /forums/images/graemlins/rolleyes.gif
  16. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    It's all about creating interest! /forums/images/graemlins/deal.gif
