sleeve it or trash it?
Discussion in 'The Garage' started by crossjim, May 29, 2004.
  1. crossjim
    crossjim Registered Member
    Dec 6, 2002
    7
    Greensboro, N.C.
    Just bought an 88 Jimmy knowing it had thrown a rod. Got it home and pulled the engine which revealed an oil pan full of coolant and three broken rods. I haven't torn it down yet, just removed the oil pan to see the carnage, but I assume there is at least one hole in a cylinder wall. I have no experience with damage this bad. Can I put a sleeve in the damaged cylinders? If so, is that a quality fix or will I regret it later? I want this engine to last a Long time. Any knowledgeable replies would be greatly appreciated.
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    pick up a good 350 block...You will come out about the same once you figure in the cost of putting a few sleeves in your current block. I saw a 1988 350 roller ready block with 1-piece RMS on e-bay a while back for like $200 and it was still unbored...
    Chris
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'd trash that block. Depending on how much you're willing to spend, a crate engine might be in order. /forums/images/graemlins/whistling.gif
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I agree about using a different undamaged block, for that matter you can probably find a running engine locally that wouldn't need much machining /forums/images/graemlins/k5.gif
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    350 blocks are far too cheap, and easy to find. I'd only try to sleeve a block that was very rare (and valuable). Find one in a Caprice and it should have a roller cam right from the factory. /forums/images/graemlins/cool.gif
