slider window removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4wood, Feb 14, 2004.
  1. 4wood
    4wood 1/2 ton status
    Jul 27, 2003
    116
    Atlanta, GA
    Does anyone know how to remove the slider windows from a hard top? Can I do it myself or is that a mechanic/stealership job? I did a search and checked the Hayne's manual and found nada.
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    i'll check mine, but i think it isn't hard for you to do
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    There easy to pull. The rubber strip seal has a thin stip in the center that expands the seal. Pull that out. Then from the inside, push the seal lip out. I can do it by my self. I put one hand through the window opening when I start it, Then finish pulling it out from the outside. I might be easier to have somebody else helping you hold the glass. It's a little harder if somebody glued the seal to the top. There not from the factory, but some people do when the put them in.
  4. 4wood
    Jul 27, 2003
    116
    Atlanta, GA
    Thanks!
